This would mean that either a CABLE BOX, SAT BOX, COAX CABLE, HDMI CABLE, ETC may not be working properly, something is loose, or needs reset.
-Reset ALL components by unplugging them for 5 minutes including the TV.
-Be sure all COAX CABLES and HDMI CABLES are tight and properly connected.
-If you CAN pull up the TV MENU when you have the black screen, update your TV’s firmware to be sure your TV is up to date and rule out the TV as the problem.
NOTE: If the TV now works and there is no BLACK SCREEN, the issue was either a loose cable, old TV firmware, or a component that needed to be reset and the issue is now resolved.
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
SOURCE: sharp aquos lc-37d43u tv
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
SOURCE: Hyundai Lcd/Tv wont turn on (Lc-23y18)
my television is the same and has been like it for almost 18mths, still to find a cure
SOURCE: when I turn on my
common problem for this particular model, one or more CCFL (backlight lams) falure. Lamps are not avalable as the replacement parts, only way to get them is to take appart bad/broken screen tv.
Stevie Nicks thank you I appreciate the help but the tv turns of as soon as the sharp logo comes on no time to pull up any menu and with this model there are no physical buttons on the tv itself
Same tv, same problem, happened today. The tv needs the firmware reinstalled, but i havent been able to get the firmware for this model.
I reset the modem, router, uplugged the tv and pressed the power button for one minute, checked the connections,then found this video https://www.youtube.com/watch?v=8jIs8Usk...
if you know where yo get the firmware please share.
Hi there. Did you guys find the firmware for this model? I am dealing with this issue and would greatly appreciate the help!
