Washing Machines Logo
Model :XQG65-908E front loading machine Displaying E30. Over last 10 days cycles have progressively failed and no longer works at all.
Machine emits a regular "clunk" when start button is pressed. What is the problem and how is it fixed
Posted by Patricia MacCallum on
ADMIN Andrew
    Top Expert:
  • Washing Mach... Master
  • 50,538 Answers
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
https://www.fixya.com/support/t21079104-stirling_xqg65_908e_manual
Posted on Apr 17, 2021
ray gallant
    Top Expert:
  • 74,163 Answers
Call your local repair service .never owned a front loader and never will
Posted on Apr 16, 2021
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
All the cycles are working but the washing machine will not rinse the excess water left. I have tried to take out the filter but this is stuck and will not move so the water sits in the washing machine. ...
Do not run the machine until you have cleared the filter or you will burn the pump out. You need to keep working the filter until you are able to get it opened and cleared.
I have a siemens waching machine model no wd11640hkbu. few days back when we were running a wash + dry cycle, while it was on the last 5 minutes of the dry cycle, there were loud banging noises and some...
Front laod washers have a heater element The siemens is mounted at the front of the drum Most likely the heater is burnt out and will need to be replaced. not a difficult problem. The heater has probably burnt itself into an open circuit situation and so the machine now still works. it may not work right through a cycle if temperature is selected other than cold.
You should not have to repalce the machine for the sake of a heater if tis is the case. Why not call knowlegable technician to ascertain this problem. For someone to assume the motor is burnt without looking is not thorough. The banging noise may have been the drum hitting against the burnt out heater element. Good luck
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
3helpful
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
1helpful
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Top Washing Machines Experts
Marvin
Marvin
