Washing Machines Logo
Hi, Our washing machine (IFB frond load senetor Aqua) is stuck at function disable Child lock and not not getting reset.it is stuck from yesterday
Posted by Lakshmi D on
  • Washing Mach... Master
  • 6,526 Answers
Look for two key pad buttons with a line with a smiling child face padlock symbol. Press and hold these two buttons until you see or here a response from the washing machine.
On a 8 Kg model, press and hold + and - Change buttons on the right of the LCD screen simultaneously for several seconds? That's the way to toggle the child lock on and off for this IFB model, https://www.amazon.in/IFB-Fully-Automatic-Senator-Aqua-SX/dp/B00LAXLN5C . On a 6Kg machine, https://www.amazon.in/IFB-Fully-Automatic-Diva-Aqua-SX/dp/B071G3B81W/ref=psdc_1380369031_t3_B00LAXLN5C , the appropriate buttons to hold are the Rapid Wash and No Cold. (These are on the right side of the control panel but to the left of the power button.)
Depending on the machine, the time to hold the buttons may be 3 seconds, 5 second or 10 seconds. You should see and hear some response. However, holding the key pad buttons for too long may re-enable the child lock.
I hope this helps. The child lock on most washers remains active even when the power is removed from the machine. This keeps the program from being activated when you clean the control panel or by a child who shouldn't access the machine. If the problem persists, I suggest checking for a problem with the keypad wiring or contacts.
Posted on Apr 12, 2021
5 Related Answers
Anonymous
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
Anonymous
SOURCE: My Bosch washing machine (WFX145SGB
Eventually discovered that if the 'start' button is held down for a few seconds it unlocks the 'child lock'.
Posted on Jan 05, 2009
Anonymous
SOURCE: machine won't wash because 'child lock' is on
Holding down the Start button for over 5 seconds turns the child lock on and off.
Posted on May 15, 2009
Anonymous
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
Anonymous
  • 2605 Answers
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Posted on Dec 22, 2010
How to disable the child lock on Electrolux washing machine EFLS617STT
How do I turn off the child lock on my Electrolux washing machine?
On earlier Electrolux models, this function should not have been enabled, but it can be disabled/enabled by simultaneously pressing the two buttons to the left of Start/Pause and holding them down for about 5 seconds, when the "padlock" symbol will illuminate (enabled) or extinguish (disabled).Feb 25, 2019
Washing machine displays padlock - Electrolux ' Help and ...
VIDEOS as well
https://www.google.com/search?q=disable+the+child+lock+on+Electrolux+washing+machine+EFLS617STT
My IFB washing machine displays CH, What is the error?
On some IFB washers, the CH indicates that the child lock (control panel lock) has been activated to avoid accidental washer use. On the IFB digital 5 KG washer, you can toggle the child lock on and off by pressing the Soak Option and Delay Start buttons simultaneously. These are the second and fourth button for the Optional settings above the LCD display on this model. Below the keys, there is a skeleton key symbol in the center of a line drawn between these two keys. You can see this information in the manual for this machine in the manual, http://www.ifbindustries.com/home_appliances/washing/manuals_new/DIGITAL_5_KGS.pdf . See page 9 (7 of the PDF) and page 13 (page 11 of the PDF).
I hope this helps. Please add a comment with your model number for information specific to your washer. If your washer uses a different set of keys to toggle the child lock on and off, you should look for the skeleton key symbol on the control panel housing. Any response to a follow-up comment may be delayed.
The child lock on my smart drum lg washing machine is on how doi turn it off please
To TURN OFF CHILD LOCK on your LG washer, press and hold the CHILD LOCK button for 3 to 5 seconds. The washer should now have CHILD LOCK mode DISABLED and all buttons will function properly.
PLEASE NOTE: ON other newer LG front load washing machines hold the PREWASH/CHILD LOCK button for 3 to 5 seconds to turn CHILD LOCK OFF.
My ifb washing machine displays CH, please help, cannot start any other programme
CH means child lock is engaged. Here’s a user manual that explains that feature. It’s on page 11.
1helpful
2answers
In IFB front washingmechain AC h1 error is coming what to do
that error occurring due to high voltage in your residing area. We believe IFB Washing Machine protects your machine by tripping. We have GA 400 Voltage Stabilizer to buck or Lower your upcoming Voltage from GEB. It has Capacity of 12 amp and 15 to 20 Voltage up /down capacity. We are sure this GA 400 model will solve your problem. You can Call on : 9722658052 or 9427347880 Thank You
2answers
Child lock in ifb washing machine
2answers
My washing machine is just washing draining but not spinning
IFB is most of the main manufacturers of the washing machine to be had in the market. The brand has brought modern designs and technological improvements for bringing range washer vacations to purchasers. Are you seeking out IFB washing machine service and repair benefits for your area? IFB Washing machine service center in Hyderabad can be outcome cloth washer to end provider measures makeshift. we're managing each description of manufacture.our skilled expert have a power, we additionally accurate other proper brands. The professional preference for all-around handover and affordable perspective. Our education commitment to give the fine reaction for our clients with, especially overall performance rate. http://aktechnoservice.com/ifb-washing-machine-service-center-in-hyderabad
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
14helpful
Machine won't wash because 'child lock' is on
Top Washing Machines Experts
Marvin
Marvin
