Washing Machines Logo
Mary Petruncola Posted on Apr 10, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front loading lg washer leaking underneath - LG Washing Machines
ray gallant
Level 3:
Top Expert:
  • LG Master 74,163 Answers
  • Posted on Apr 11, 2021
ray gallant
LG Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
655451
Points
561709
Possibly the bearing seal is gone , suggest calling a local repair service
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Aug 14, 2006
SOURCE: LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Anonymous
  • Posted on Jan 22, 2008
SOURCE: Kenmore Washer Leaking from underneath
check the hose from the bottom of the drum to the drain. it probably slipped off. its held on by a tension clip. Someone must have pulled on the hose at the back.
Anonymous
  • Posted on Mar 30, 2008
SOURCE: water leaking from underneath after washer drains
I have the same washer and there is a white plastic piece underneath the washer where two hoses go into. It contains the impeller that pumps the water out. Anyway, on my machine this piece was incorrectly injection molded at the factory. The glue bubbled out causing an air bubble -- once the air bubble in the glue can stand the pressure and pops, the leak occurs!!!!! If you are a handyperson, take this piece out and use exopy to fix.
Anonymous
  • 1902 Answers
  • Posted on Feb 16, 2009
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Anonymous
  • 15 Answers
  • Posted on Apr 18, 2009
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
1helpful
Leak under my front load Lg Tromm washing machine
Have you checked the internal hoses and the drum seal?
2answers
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
2answers
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
LG steam washer leaks a small amount of water from underneath the washer between loads.
Hello.
Welcome to Fixya.
  • Inspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the Water Pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
1helpful
3answers
Water leaking from my front load LG washer
My LG WM2277HB also leaks after 4yrs of use. I found a hole in the front door gasket at the 3 o'clock position. I also have LE errors constantly.
Help please water leak
HERE is your service manual MAybe that will give you an idea
LG Dishwasher 4.0 cubic feet Leaking from underneath the front door
Maybe you should get someone to patch it,.. or you could just get a new one,..
1helpful
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
