Car Audio & Video Logo
Question about Car Audio & Video
Car stereo faceplate falls out - Car Audio & Video
Posted by Gordon Bates on
Aron
    Top Expert:
  • Car Audio & ... Master
  • 2,323 Answers
The reason why your faceplate keeps on falling out for your car stereo is because that part needs to be replaced.
Posted on Apr 10, 2021
I need unlocking code of radio cd hm-5064
Instructions
    • 1Remove the faceplate around your stereo. Slip a flat object under the edge and gently pry it up. A flat-head screwdriver works well. There will be clips holding the faceplate in place, so feel for them. You may need to move your faceplate up or down to slide it out of position.
    • 2 Find and remove any screws holding the stereo in place.
    • 3 Slide the stereo component out far enough to see the label on top of the stereo. Write down the model and serial numbers of your car stereo component.
    • 4 Locate your VIN number at the base of the front window, driver side. If you can't read your VIN off the window, you will have it on your proof of insurance and title as well. Write it down.
    • 5 Locate your car manufacturer's toll-free Customer Service number and call them. Click on the link in the Resource section of this article and find your car manufacturer's toll-free number.
    • 6 Call the number and let customer service know you need your stereo code and have the vehicle's VIN number, as well as the model and serial numbers off the stereo. They will provide you with the code. If you are unsure how to input the code, be sure to ask for support at this time.
1helpful
Is it possible for me to get a car stereo without the faceplate as i recently had mine stolen but still have the faceplate would really like to know please help!!
Unless you find a stereo body on ebay, a pawn shop or possibly goodwill, you can not buy just the body of the radio.
How do I unlock my Kenwood KDC-MP528 car stereo
To reset the code do the following:
1) Turn on the car.2) The faceplate rotates out and the CODE - - - - prompt appears.3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
For further assistance please let me know.
How do i detach the faceplate of a pioneer deh-p3700mp car stereo?
Normally it is the button on the top left or bottm right of faceplate. it will spring the faceplate out at an angle, then you just pull off.
Don't know what faceplate to buy for Kenwood Stereo SER# r8188309
So if i understand your question correctly, you still have the stereo in your dash, but the face has been stolen, is this correct, Because if this is the case you can remove the rest of the stereo from the dash and somewhere on this unit it will tell you what model it is.
Can anyone help.... my stereo faceplate doesnt work the buttons light up but the display doesnt any solutions???? a friend have the same as me and I put the faceplate on his and it work so i dont know what...
Does the stereo have a lock? Maybe its locked or something.
What kind of stereo? Car stereo?
Try turning off completely and turning back on.
-Ryan
-please rate
Sony XR-C2600 car stereo stuck in demo mode
Sony XR C2600
  • Press release button on faceplate.
  • Remove the faceplate.
  • Clean the contacts in system and faceplate with alcohol.
  • Voila, all button works now
Bullet Sankar India
No faceplate for stereo
Try this link http://www.tune-town.com/ they should have what you need. Just pull out your unit and give them the model number
Accidently removed the tiny screws behind faceplate
It could just be a plastic clip that broke.Most of the car stereo's ive taken apart only have a thin ribbon of wires that run into the contacts that your face plate connects to.If you actually took screws out of the faceplate then id put them back in and put it back into your stereo and see if it illuminates properly,if it does not then id search on E-BAY or contact pioneer and buy a replacement but most the time it would be cheaper to just buy new stereo.You might want to be more specific with the area you took screws out of,the way im reading it sounds like you unscrewed the screws in the face dock, not the faceplate.Hope this helps.
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
