Achieving Smoky Eyes.If you're looking for a way to play up your eye color, go smoky. A smoky effect makes eye color pop and creates a dramatic evening look. Read on to learn how to create a flawless smoky eye. <br /><br />Create a smooth canvas for eye makeup. First, you'll want to apply a primer to your entire face, including the eye area. Then apply a concealer to get rid of redness and dark circles. Finish off by applying a moisturizing foundation to create a flawless canvas. <br /><br />Apply eyeliner. Use a black liner and draw a line across the upper lash line. When you get to the middle of the eye, make the line a little bit thicker. Choose a lighter-colored eyeliner and line the bottom of your eye. Smudge the liner with your finger to create a smoky appearance. <br /><br />Apply two colors of eye shadow. In order to select the right products, check out eye shadow reviews. You'll want a color palette that has both a light and a dark color, such as L'Oreal Paris HiP Concentrated Shadow Duo. Use the lighter color as a base and blend the color all over your upper lid. Then, apply the dark eye shadow, starting at the lash line and blending upward.
The virus is spread through direct contact with fluid from the rash blisters caused by shingles. A person with active shingles can spread the virus when the rash is in the blister-phase. A person is not infectious before the blisters appear. Once the rash has developed crusts, the person is no longer contagious.17 Sep 2014
Add an instant pop of attention-grabbing sheen to lids with stila's High Shine Liquid Vinyl Eyeliner. This chic liner is infused with pro vitamin B5 and glycerin to help nourish, condition, and moisturize the lash line and delicate eye area. Filmogen provides exceptional adhesion and delivers long-lasting results. Whether you're drawing a fine, precise line or creating a bold stare, the fine brush tip makes application a breeze.
One of the micro switches has gone bad take of lid open and close,the door and you will see the door latch pressing in a button on the micro switch look and see if can spot one with a button not popping out nicely like the other ones if you can't see any problem with your eyes you would need to use a multimeter to test them
Check you heating element for blisters or cracks the elements are usually the first to go, if not a wire may have burnt off the backas far as a fuse not knowing model no. i would say there is none unless it is digitally controlled
