HP Deskjet 3755 Wireless ' 123 HP Setup 3755 Wifi ...
SOURCE: unable to connect through wi fi
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
a36
SOURCE: Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
SOURCE: Toshiba does not connect to wi-fi unless other laptop is on wi-fi
1. Reinstall the wireless driver.
2. Restart your system.
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
SOURCE: cannot connect to wi fi with my toshiba
make sure you have switch on satelite fn and f2 key together or a switch on platform
RTM manual at HP.com yet
it has every step there.
no need for others to post what is in the manual clear as day.
https://support.hp.com/us-en/product/hp-...
OMG all 3 manuals are gone there, shows silly HP mindless OOPS. (they have vast bad links there and sad to see it endless)
but is SSL errors, http not https.
but now works. I had to try 3 times.
there are 2 ways. or 3 using smart app.
learn your router credentials (at home?)
or use WPS. or pin. way. (some routers now do not have PIN way and only WPS button.
the printer is not old still sold at newegg and vast others.
odd that HP support page is dead. very odd.
this printer has toggle switch
if was set to USB must be reset to use WIFI connections, or wifi will not setup.
seen it me, done it.
use USB connected is more easy.
wifi,
good links. USB/WIFI toggle mode.
think of it as 2 printers.
now wifi.
you need the HP smart app. to setup wifi.
so ways this page
https://support.hp.com/us-en/document/is...
ok HP was down above.
now works (non SSL pages, but ok)
http://h10032.www1.hp.com/ctg/Manual/c05...
or
