Question about Behringer Music
I have a Behringer Europort EPA900, 900W Portable PA System. The sound cut off in the middle of use but the power stayed on. I did order new fuses and changed them but no sound. Any suggestions?
Posted by Wilson Ramos on
Fred
    Top Expert:
  • Behringer Master
  • 35,762 Answers
The amplifier may have destroyed itself. Take it to a Behringer Authorised Repair Shop for repair.
Posted on Apr 05, 2021
How can I service Behringer epa900 speaker
Can't say for sure....there should be a bunch of screws in the back so you can gain access....is this a powered cabinet??...can you dis-connect the present speaker and horn and hook up another just to make a test?? Is the cabinet plastic?? There could be loose screws....Does the cabinet have a recess for a stand??If so, check the retaining screws in that as well....and don't forget to check the grill....
No audio and damage parts broken
The first thing you have to do is replace the damaged parts and repair any damage to the circuit board. After that you will have to tackle the no audio problem if there is one...repairing the damage might solve everything...and it might not.....it is very hard to tell because I can't see the unit.
Schematics diagram of epa900
Good luck......Behringer does not release schematics....you will have to do it without them unfortunately.....unless you can find somebody who has them...Check for a forum on the net for Behringer equipment...you might be lucky to find something there.
2answers
No sound from speakers how to fix the problem
Assuming that you've checked the fuse, and the lights come on...
1) Can you hear any "hiss" from the speakers at all?
2) What have you tried to input into the device? (guitars, keyboards, mics, etc.)
3) Have you reset all buttons to "basic" mode?
Let me know, and we'll go from there...
2helpful
What are the sound effects provided on the Behringer epa150 PA?
The effects should be the same as the EPA900 unit. Get the brochure here and look for "Effects Table." Hope this helps! http://www.behringer.com/assets/EPA900_P0431_M_EN.pdf
Does anybody have a schematic for the separate power supply unit integrated into the Behringer Europort EPA150 Portable PA System?
If it sits in between the incoming live connection & the mains input to the PSU then it will most likely be an NTC. That's a resistor with a Negative Temp Coefficient. At room temp it's a high enough resistance so as to limit the inrush / surge current at switch on. Then as it warms up from use the resistance goes down & the unit works normally. Something like this is worth a try... https://www.ebay.co.uk/itm/2-x-NTC-5D-9-Inrush-Current-Limiter-Power-Thermistor-5-ohm-3Amp-ref-403/282807213327?hash=item41d89f9d0f:g:R5EAAOSwMgdX0vHs
1helpful
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
How do I connect an ipod to my EPA900 ? also, I have a digital recorder with a USB connect. Is there a converter product that I can purchase that will allow me to connect this recorder to the system?
It is unlikely to find a compatible USB convertor for that digital recorder. If it has audio input you can probably use a similar cable to that for the IPOD described next. For the IPOD, get a 1/8 inch STEREO splitter cable that splits to 1/4 inch plugs or RCA plugs to connect to the PA system. Radio Shack will probably have a suitable one.
1helpful
I have Behinger Europort EPA900, One speaker crackles, tried swopping cables etc, but nothing helps, the problem seems to be definitely with the speaker.
Open the speaker and look for loose connections. Carefully move cone with fingers. If there is noise when doing so...rubbing type noise, speaker needs reconing or replacing. If the crackling comes from teh tweeter section, then the tweeter may need replacing.
Music Logo
Top Behringer Music Experts
Mehandi Husain ...
ray gallant
Are you a Behringer Music Expert? Answer questions, earn points and help others
