Question about Bose Audio Players & Recorders
Can you connect a Bose Lifestyle 5 system with an Bose Acoustimass 9 powered speaker system?
Posted by Felix Santos on
ray gallant
    Top Expert:
  • Bose Master
  • 74,163 Answers
Nope sorry
Posted on Apr 11, 2021
5 Related Answers
Anonymous
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Posted on Mar 01, 2009
MB Audio
  • 19 Answers
SOURCE: Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
Posted on Jun 18, 2009
Anonymous
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
Anonymous
  • 944 Answers
SOURCE: I have a Yamaha Receiver
No it is not compatible to use RX-V 467 with Bose Lifestyle Acoustimass 9.RX-V 467 is a 5.1-channel AV Receiver.
Bose Lifestyle Acoustimass 9 subwoofer are designed to be used with their special equalizer and require a 'Pre-Out Main-In Coupler' or 'Tape Monitor' connection. The compatible models are the:
  1. RX-797 (Pre-Out/Main-In)
  2. RX-497 (Tape Monitor)
  3. RX-397 (Tape Monitor)
  4. AX-596 (Pre-Out/Main-In)
Even though you try to connect it will have buzzing noise or no sound.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 14, 2010
gopakumarg43
  • 76849 Answers
SOURCE: What is the impedance of
Hello
The impedence of all speakers are [3.5 Ohms]. May connected upto [6Ohms] instead, provided the output will be a little less. Bass module cannot be connected with other sources. If you are intented to hear the music on an other room you can add speakers. For more detail, go to page [29] of its user manual, where all details and switching data are provided. All cannot be send by this window, as it will be out or capcity of this answer window. If you haven't its user manual with you now, send your email address to me by FixYa. I'll send a copy of it to you by return mail.OK.
Posted on Jun 02, 2011
Can I use a Pioneer Elite VSX- LX101and a Bose Acoustmass 9 powerized speaker system.
You are only given one answer from our Expert Ray with the brief answer 'No sorry'.
This is your VSX
REAR TERMINALS
HDMI 4 in
HDMI 1 out
AV (Composite) 2 in
Audio 1 in (assignable)
Digital Coaxial 1 in (assignable)
Digital Optical 1 in (assignable)
Monitor Composite 1 out
Preout 0.1ch (SW)
Speaker 5 ch out (FRONT, CENTER,
SURROUND)
and this is your Bose. Find the manuals for both and read them. connecting them
https://www.techwalla.com/articles/bose-acoustimass-9-speaker-system-installation
A: Glancing at the specifications of the Bose Acoustimass 10, the system is stated to be compatible with A/V receivers and amplifiers rated from 10-200 watts per channel, and from 4 ohms to 8 ohms. Aug 17, 2014
Q&A: I Have A Bose Acoustimass 10 System, What Receiver ...
It is a pity you don't have a newer one that can be connected via HDMI lead.
2answers
Where can i find a replacement audio input cable for acoustimass powered speaker system model 2683 5 pin din
See on ebay.com for used or new one of it as other trading sites sell quantities. Such as alibaba or aliexpress for chinese or amazon for better qualities
1helpful
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
3helpful
Please help i have matsui dav50 home cinema dvd player and cannt change it from 2.1 to 5.1
i have Bose - Acoustimass® 20 Powered Speaker System without the lifestyle, can i connect a pre amplify to it
2answers
No power to my speakers. How do you open the amp? BOSE acoustimass 5 Thanks
A powered AM5 bass unit? Undo the 1/2 screws, tease out the toothed quadrant by 90deg then tap the plastic panel down/away from the toothed quad. not easy the clips are usually very tight.
Bose acoustimass 9
Did bose make a Acoustimass 9 series
4helpful
3answers
Acoustimass 9
Acoustimass 10 IV cable
5helpful
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Top Bose Audio Players & Recorders Experts
Marvin
Marvin
Steve
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
