Question about Polaroid Televison & Video
I have a ge universal cl5 remote need code for Polaroid HD LCD TV and DVD player combo tdac#02212 22" flat screen
Posted by John Simmons on
john h
    Top Expert:
  • Polaroid Master
  • 24,971 Answers
Https://www.directutor.com/content/ge-universal-remote-instructions This is your manual for remote but most universals are not comparable with combo units
Posted on Apr 03, 2021
Tom Chichester
    Top Expert:
  • Polaroid Master
  • 62,168 Answers
Use code search on your GE URC to find something that works. You may need separate codes for TV and DVD player. If a search through all codes stored in the URC fails, try a different one.
5 Related Answers
Anonymous
  • 291 Answers
SOURCE: universal tv remote control codes for a hikona tv/dvd combo
you have to set the code for TV alone, then code for DVD
Posted on Apr 27, 2008
Anonymous
SOURCE: remote code
I NEED OTHER REMOTE CONTROL AT POLAROID TBX-2000AF 20 IN TV/VCR/DVD COMBO. THANK YOU
Posted on Nov 09, 2008
Anonymous
SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Posted on Dec 09, 2008
RNS-Systems
RNSeStore.com
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
Anonymous
  • 2335 Answers
SOURCE: Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
______________________________________
Polaroid FLM-3232 Manual Download
Polaroid FLM-3232 Service Manual Download
Posted on May 01, 2010
I have a polaroid flat screen tv with a dvd player bult in. i need help finding the code to set this up on a ge universal remote
DEPENDS WHAT KIND OR MODEL AND BRAND OF UNIVERSAL REMOTE E.G UR22B COS EVEN UNIVERSAL REMOTES HAVE THEIR ON CODES
1helpful
We have a 22" Polaroid flat screen combo TV model #TDAC-02212 and the remote IERC03 does not work. Can I get another remote - the TV works with the built-in controls.
Dear Colleen,
Yes You Can, Try Typing "TDAC-02212 Remote" In The Amazon Search Engine. About $40 To $45 Bucks. It Should Come With A Manual On How To Program It To Your TV.
Wrong region
You maybe able to get a region free code from one of these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Codes for uneversal hd toshiba dvd combo tv
A universal is not likely to work for a combo unit---best bet is to Google the model number of the set and try to get an Original remote for it.
Can't get universal remote to work for polaroid tv/dvd combo
read here
http://www.fixya.com/support/t225581-code_polaroid_tv
4helpful
4answers
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
2helpful
3answers
Remote code
Sharp 42" lcd remote code for a polaroid vcr/dvd
I hope that helps.
Televison & Video Logo
Top Polaroid Televison & Video Experts
Ekse
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
