I also had to manually eject a stuck tape since the tray would not open and noticed two of the guides were loose and idk if that has anything to do with it and whether or not it would also be a major or minor issue.
This device is many years old now - even if a repair were feasible, it would be prohibitively expensive. Time to replace with a more up-to-date model, which will have the added advantage that you can load video files directly your computer from the memory card.
You may have tapes already recorded on your old machine - these can be transferred to DVD by any competent camera store.
Testimonial: "rip"
SOURCE: cAMCORDER WILL NOT PUSH IN A TAPE, STUCK HERE
Posted by delmas263 on Jan 02, 2009 I have the same problem, The camcorder will not take in the tape, stuck the tape holder will not go back in, notify me when you have a solution. Thanks
SOURCE: Tape ejects on a JVC GR-D275U camcorder but will not autoclose
Threw it in the trash can a bought a Kodak
SOURCE: JVC Camcorder Model # GR-D270U
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
SOURCE: problem ejecting tapes getting stuck
The take up is not rewinding the tape all the way back into the shell. Check the idler, it's either worn or if it's plastic it is warped from the heat.
