Question about GPS
I updated the GPS on my sound stream vrn-dd7hb and it no longer works it freezes every time I try and use it how do I reset my double dinn
Posted by Mario Melgar on
ADMIN Canada
    Top Expert:
  • GPS Master
  • 40,116 Answers
Reset button, Page 7 of the manual
VRN-DD7HB Manual - Soundstream
soundstream.com > manuals > Soundstream-VRN-...
PDF Eject Button Touch this button to eject a disc. If the disc is not removed for about 10 seconds after eject, the disc is reinserted automatically. Reset Button Press it with a thin, sharp object. The unit will then be reset to factory default settings.
Posted on Mar 26, 2021
I have a sound stream PRN 74 HB need to know how to reboot it
https://www.youtube.com/watch?v=OWz7Cofdwow
https://www.cnet.com/products/soundstream-vrn-74hb-navigation-system-display-7-in-in-dash-unit-full-din/
VRN-DD7HB map update issues
You should double check that you have enough space to update if not get a usb chip to download the data on.
5helpful
2answers
My Garmin Nuvi 660 touch screen is frozen. I've tried to reset it with the switch on the back. I've tried connecting it to my computer to reset it. Powering on and off don't work.
Sounds like your firmware needs updated. Just go to Garmin’s website then downloads and update your firmware. As long as there is no screen damage but just touch screen not working that will fix it. An easy test is to take out the battery and if the unit works for second then freezes you just need to update firmware. Turn off unit plug into computer via usb cable and do firmware update, that easy!!!! Hope that helps?
5helpful
When I turn on my magellan maestro 3200 it just says Magellan and stays on that screen . What is the problem ? I just bought the unit from ebay and this is the firt time I'be tried to use it . I read the...
whether its new or used, this can happen for a few different reasons. sometimes they just freeze up there and then they freeze up when someone has tried to update it and the updated failed before it was finished installing it.
hopefully all it will need is a reset...looking at your 3200, look on the left side of the gps and you will see a hole that you can insert something like a paper clip in..turn on your 3200 and insert a paperclip in the hole and gentle depress the reset until the unit restarts...
if it still will not go past that screen, just let me know and i can tell you if you can and how you can, reinstall the update and or tell you how to get magellan to repair it for you for free.
the reset normally works 98% providing the files are not corrupt
bill
2helpful
Green light comes on,but device doesnt,it may take a long time,it seems like it freezes
Mine does the same but only very occasionaly.
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this.
I think that sometimes it just glitchs although it is rare
You may also want to use TomTom Home to update the GPS
Screen freezing on switching on
Seeing a few start up issues around at the moment but am not sure if it is a tom-tom update issue or just the tom-tom itself.
2answers
My 700 gets stuck with the last map
Same problems, you have to update as far as I know and you have to update every year otherwise it will start to freeze up. It's a rip off because it's $99 a year. Does anyone know if the other GPS companies do this?
GPS Freezes
Try download the latest update from Garmin.
GPS Logo
Top GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a GPS Expert? Answer questions, earn points and help others
