HL-30c manual can it print from iPad - Office Equipment & Supplies
Posted by toby crowell on
How to print both side in hl-2130
Hi there.
The HL-2130 does not have an auto-duplexing system included in the machine. If you wish to duplex print you need to print the first page then feed that page through the Manual Feed system (Side to be printed up, top of page first) and print the second page on the manually fed page.
Pump was running fine until pool water reached 30C is there thermal protection? where is the reset?
That does not appear to be that hot. The reset can be automatic or manual depending on the motor used. That information would be in the manual or if it is a manual reset it would be the red button on the motor. Be sure you have power to the pump first. The 30C may just be a concidance.
How to print from ipad 2
Hi There
Read this article and know how to print form your iphon or ipad
or
http://support.apple.com/kb/ht4356
Downlaod the AirPrint:
AirPrint Activator Windows Download: http://tinyurl.com/AirPrintWINENG
AirPrint Activator MacOSX Download: http://youtu.be/9r75m_VUr0E
http://www.youtube.com/watch?v=
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
The Brother HL-2140 does not include duplex printing. The only option for double sided printing with this model is to print odd numbered pages, then manually replace the paper into the tray and print the even numbered pages in a second set.
Regards,
Dan
IT Professional
2answers
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
Only blowing cool air, even having set on 30C on remote. No user manual.
Mate, I had exactly the same problem. When I set the thermometer to 30c it cut out, then five minutes later it started blowing hot air out. Hope this helps!
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Marvin
Marvin
