THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY
2 CLEAN FILTER
3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS
4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK
1 DISCONECT UNIT
2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT
KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START.
3 STOP THE UNITS OPERATION BY PRESING ON/OF
4 RESTART UNIT.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit 2. hold the Power button while plugging the unit back in 3. keep holding the Power button until the unit beeps 4. unplug unit again 5. plug it back in and it should be good
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify. If the issue persists, please perform the following steps: Step 1: Power Reset: 1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit. 2. Wait 30 seconds. 3. Plug-in only the ‘power cord’. 4. Repeat steps 2-4 two more times. 5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer. If the issue persists, perform the following steps: 1. Take the cartridges out of the unit. Unplug the power cord from the unit. 2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit. 3. Turn on the unit and insert the cartridges. This will solve the problem...
You have a bad power plug on the unit. The solder connection are loose. The one have is doing the same thing. The power plug pins have came lose and need to be resolder. Working on how to take the unit apart to solder the connection.
Did you try to plug a lamp into the same outlet as you have the A/C plugged into? It could be that you have no power at the outlet or the circuit breaker could be off or tripped. Something should run like the fan only position.
