I suspect your signal has gone so poor it cannot receive a signal any more.
Follow this;
https://www.openview.co.za/setup-guide
If that is no good, call an aerial instalation techncian.
SOURCE: won't turn on
unplug the main power to the power supplie.take the batterie out from the motherboard.
plug it back in.
turn it on.
replace batterie .
if this dosnt work your power supplie may have died randomly.
SOURCE: I went on Facebook on
In the Upper right hand corner you need to click on account then select the logout feature.
Did you check the battery?
SOURCE: i have a 2009 VW Fox and cannot open passenger side door?
Take off inside door panel...check rod from lock to handle. May have bad handle.
SOURCE: My decoder is not responding to my remote. Every
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
