Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it.
https://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
https://electrohelponline.blogspot.com/
Posted on Apr 16, 2021
SOURCE: Green power light comes on, but the screen is black and will not respond to anything
unplug from the wall and wait a whole day then plug bak
Posted on May 12, 2009
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Posted on Jul 14, 2009
SOURCE: Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Posted on Sep 15, 2010
SOURCE: I turned my t.v. on w/the remote. it came on then
Hello; This problem is likely caused by bad inverter board(s). I think there are 2 on the left side on this model. If either inverter doesn't start, the microcomputer on the main board see's this and generates one "lamp error" . Once it counts 5 lamp errors, the screen will not light and led(s) will flash. These boards are about $100 each and no way to know which is bad. It can also be caused by a bad LCD panel ( cost more than the TV sold for). You can verify a lamp error problem by doing a "forced start" . The set must be unplugged. then"I think" Hold the channel up and volume down buttons on the set or VISa Versa, and plug in without releasing these buttons for several seconds. If the set makes a buzzing noise , the power supply board is bad. If the set comes on and stays or goes off this is the inverter and/ or LCD panel problem. John
Posted on Dec 10, 2010
SOURCE: Hi, My DSTV decoder is
press the shift button, its stats flashing than press the info button (tv1) works every time
Posted on Feb 08, 2011
