It starts ok, sounds like it's draining initially and after about 30 seconds the Intensive and rinse buttons start flashing and it keeps beeping and doesn't run.
SOURCE: Whirlpool dishwasher adg7540
where do you live that model doesnt come up in my data base the first thing your washer should do when you turn it on is drain then fill then go to wash try this it should put it in self diag if this dont work reply we will try another
HIGH TEMP SCRUB, AIR DRY, HIGH TEMP SCRUB, AIR DRY push thoose see if it goes into self diag
SOURCE: fast and delicate flashing
Your control panel is bad.My advice is use your warranty if you have it .If you don't ,toss this machine out,there should have been a re-call on this .You are one of many many that are having to deal with a problem that the manufacturer should be liable for. Dont't let GE (hotpoint) go not knowing that your D/W is broken ,look for a class action law suit to be in the making,which is not enough to correct the problems at hand .I don't advise repairing this unless there is a modified part to replace the defective one. Again I'm with you on this ,and sorry for all the consumers that are ripped off by manufacturers (in my eyes) . Please rate this !
SOURCE: I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
SOURCE: haier dishwasher
I useto have same problem. For some reason there was water under machine, then i tilted machine, clean water and problem solved. This is built-in dishwasher that is why water acumulates under machine and "leak cut off switch" turn off machine. You can't reset machine while you have water under, machine telling you there is a problem, but Haier wan't put solution on their site - Haier suport is very bad. Sorry for English and hope this help.
SOURCE: cda cw 496 dishwasher runs cycle till rinse light
cda cw496 stops after a few minuts then just beeps help me with my problem please
My EWD1477 was doing this a year ago and I fixed it. Then it started
doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry
sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn
the machine to off with the Program Selector Dial. Then turn off the power at
the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button
should be flashing and the green lights on for Prewash/wash, Rinses and
Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty
any excess water. Press it again immediately after you hear water flowing into
the machine OR two audible clicks. The machine is now in pause mode with the
green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash
button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause
button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing
into the machine and the three green lights mentioned above are back on, turn
the Program Selector Dial back to off, wait 10 seconds, and repeat the process
above.
Step 5: If when you then turn the Program Selector Dial to
Whites/Intensive and hear the two audible clicks, immediately press the
Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then
press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
