Question about Dell Computers & Internet
Pls I have dell inspiron 1300 with this service tag,how can I reset or bypass administor password?
Posted by RIGHTEOUS TECHNOLOGY on
  • 5 more comments
  • Anonymous Mar 08, 2021
    I can only guess why you did not ask Dell.com
    for help, and come here first why?
    well you lost the old PW
    this laptop is 16 years old today.!!! a relic.
    all the batteries in it that old are NO GOOD.
    THE RTC NVRAM COIN cell battery is no good.
    the big battery just remove it leave it out.
    run on AC power only.
    the RTC battery must be replaced.
    or BIOS will lie to you, big time.
    do not skip this step or you will fail.
    it is under the keyboard RTC coin.
    https://downloads.dell.com/manuals/all-p...
    now the COIN is good
    power on and at pw, if still asking BIOS PW.
    is it?
    then hit enter 3 times, does the PW box
    show a "magic code there?">>>>>>>>
    tell this now.
    best it to use this.
    https://www.biosremoval.com/dell-passwor...
    they want 10 bucks.
    if you dont use dell.com what can you do.
    you google. PW hacks are NOT THE SAME on all PCs, made, it varies by model. vast.
  • RIGHTEOUS TECHNOLOGY
    RIGHTEOUS TECHNOLOGY Mar 08, 2021
    A brother gave it to me.the screen was broken I sent it to be replaced .when I asked him of the password,he said is a long time so he cant remember
  • Larry Ng
    Larry Ng Mar 12, 2021
    yes , why is not important here or how.
    only how. and answered above. if you read it.
    did you ask at DELL.com for help.
    ask the maker, for PW reset.? why not?
    I told you the 16 year old battery is bad.
    the RTC battery has zero chances of being good.
    now.
    would you replace the engine in your car with a dead car battery, if yes, why, ?
    batteries are first not LCD screens/
    first things first. rules..
    what your are asking is for us to be the poor fools in the middle.
    you , US, and your repair show.
    why not ask them to fix it again.
    obviously they did not, bingo?
    this is the battery on 1300.
    keyboard removed.
    below 2.9vdc the battery is NO GOOD.
    and must be replaced first.
    or the BIOS will never work right again!!!!
  • Anonymous Mar 12, 2021
    this PC has no future. it is too old
    are you going to run XP for 20 more years.
    you put a new $100 USD LCD screen on a zero value PC? yes? wow. that was brave.
    what to do if wild and love pain of relics.
    park the new useless 16year old battery. huge. run AC power pack now, only, and even for ever if that floats your boat.
    JOB1:
    1: install new RTC coin cell, $1 or tad more.
    2: connect external monitor to jack named that. and test the PC .
    3: oops has locked down BIOS admin password.
    if you can not cure that save the expense of buying new LCD.
    the cures are above if you can read./
  • Larry Ng
    OP click the xx comments box. to see all commons, fixya hids them.
    above is photo of your RTC coin cell
    actual 1300 locations. see it?
    this is first ! on all old PCs for sure over 5 to 7 years old yours is 16./
    https://www.fixya.com/support/t15244157-...
    you posted 2 times,
    why? the above has an answer.
    did you read it >?
Lewis Maina
  • 3 Answers
Download Offline NT Password & Registry Editor (USB version) from this link http://blog.omotech.com/?p=830 and follow the prompts to bypass admin password
Posted on Mar 11, 2021
5 Related Answers
getbackwindo
  • 84 Answers
SOURCE: i want the master bios password of labtop model
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Posted on May 19, 2009
hdwskai
Lucy Li
  • 85 Answers
SOURCE: pls i want to unkock my dell latitude d620 Administrator password
you forgot to tell us what password.
Is it a bios password or windows password?
For Windows Password, As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type \Administrator\ (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
Windows password Recovery software:
for example: Any Windows Password Reset 7 . It is easy and convenient to use.
http://www.windowspasswordreset.net
For Bios Password, also two methods.
1st method . Open you computer box and Discharge to the Board manually
2st method . use BIOS/CMOS Password Recovery Tool
please visit http://www.biospasswordrecovery.com/
Hope it help to you.
Posted on Jun 23, 2010
Anonymous
  • 17 Answers
SOURCE: dell inspiron 1545 sevice tag #
Try w6w2q9x8
Posted on Dec 28, 2010
Bios Pro
  • 72 Answers
SOURCE: I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Posted on Oct 01, 2012
Bios Pro
  • 72 Answers
SOURCE: dell inspiron 2200 need master password please
Go to: http://dell-inspiron-2200-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
I have a Dell laptop that will not boot up. It requests theBIOS password but ive lost it
According to the following website...
Dell Inspiron BIOS Password Recovery
Each Dell Inspiron has a master password that clears the BIOS password. Call Dell Technical Support at (800)624-9896 to get this number.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Inspiron.
If the current user is not the original Inspiron owner, Dell will transfer the used Inspiron's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
To transfer a used Dell Inspiron's registration, fill out the Transfer of Ownership form on Dell's web site. See... http://www.tech-faq.com/reset-dell-bios-password.html
Jul 16, 2014 | Dell Inspiron Computers & Internet
Dell inspiron 1300 laptop administrator password reset
You have to enter the password to be able to use the computer. There is no way to recover the password. Passwords stop other people from using your computer. If there was a way to bypass it, passwords would be absolutely useless in protecting your computer from unwanted people gaining information about you.
Feb 13, 2014 | Dell Inspiron 1300 Notebook
Forgotten bios password I have a dell inspiron 1545 service tag # 9VZD3K1-595B
Each Dell Inspiron has a master password which will clear the BIOS
password. You can get this number by calling Dell Technical Support at
(800)624-9896.
Service Code from the bottom of your Inspiron.
If you were not the original owner of the Inspiron, Dell will transfer
registration of the used Inspiron from the original owner with only
To transfer the registration of a used Dell Inspiron, fill out the
Mar 20, 2011 | Computers & Internet
I am trying to reset the BIOS password on a Dell Inspiron 1545 with service tag HC71XJ1 and Express Service Code 37742741245, can you provide help?
if you are not able to unlock this you should contact me for a better solution at
[email protected]
we can solve your all power on problems
Aug 30, 2010 | Dell Inspiron 1300 Notebook
Need help with inspiron 1501 bios and hdd password
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
If you were not the original owner of the Inspiron, Dell will transfer registration of the used Inspiron from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
To transfer the registration of a used Dell Inspiron, fill out the Transfer of Ownership form on Dell's web site.
Oct 12, 2009 | Computers & Internet
May 28, 2009 | Dell Inspiron B130 Notebook
Open Questions:
Computers & Internet Logo
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
