My ovhd decoder shows a green light only even without Lnb connected tried to reboot but still nothing is showing up It used to switch red and green light on starting up then green when it's now On but currently there is only a green light with zero display
SOURCE: cant get tv to turn on
what color does the light on the front of the tv show and is it flashing?
Posted on Apr 05, 2008
SOURCE: PS2 Slim light turns on but no display
i've find a solution to this
a blown display chip is the culprit
as for my case the m,odel is SCPH 30000 (version 4 with gap)
I replaced the BA5815FM chip and now it works fine
i hope this will help
Posted on Jun 25, 2008
SOURCE: Internet Light Stays Red on WAG54GS Wireless Router
If your router's internet light is red it means to say that there's no connection. You really have to call Tesco.
Posted on Aug 21, 2008
SOURCE: Red Indicator Light stays on-- "Online Error."
tray to powering off the printer wait about 10 second then swith on
i use to be too
Posted on May 01, 2009
SOURCE: Blackberry red light then reboots!
This behavior indicates that no applications are installed on the BlackBerry smartphone.
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing
applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION:-
1) Verify that BlackBerry Device Software is installed on the computer.
2) If the BlackBerry smartphone is connected to a laptop computer using a docking station,disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
3) If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
4) If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
5) In the BlackBerry Desktop Manager, double-click Application Loader.
6) Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Posted on Nov 19, 2009
