Question about HP LaserJet 2300 Printer
Probably smeared on the turn around.
Posted on Apr 17, 2021
Sorry we are not HP tech support
Posted on Apr 16, 2021
SOURCE: Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Posted on Sep 24, 2007
SOURCE: HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Posted on Jul 15, 2008
SOURCE: HP Color Laserjet 5550 not printing duplex
Hi, Check that the printer driver has duplex (double sided) turned on.
That's if u hav not already solved it :-)
Posted on Sep 17, 2008
SOURCE: Only prints duplex
There's a firmware update and driver update available on the HP.com website...
I'd recommend updating both and then seeing if the problem remains...
Posted on Jan 24, 2009
SOURCE: Duplex copying on HP Photosmart C8280 All-in-One
Open HP Solution Center, click on Settings, click on Scan Preferences,
select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a
check box towards the bottom of the window which would say 'scan both
sides of the original document'. check that box and start scanning.
Posted on Jul 22, 2009
