Send it back under Warranty. $99 new!
https://wohomeshop.com/
Send it back since it's still under warranty.
SOURCE: After case swap, NDS powers on 2 seconds, screen flickers white, then goes out
Its very possible that you may have fried it, even if the wrong wire touches another wrong wire, it could fry. Im not too tech-savy for DS's, but Try putting it bck in the old case, see if it works, if it doesnt you know its fried.
ope this helps.
Have a good new year.
SOURCE: Acer travelmate 2300 motherboard problem
Sounds to me u hav not done proper Soldered it onto the motherboard. CHECK THE WIRING AGAIN.
SOURCE: Acer Aspire 5600 wont turn on.
Ther is only one thing that you have not tried I think. Try to remove the CMOS battery from the motherboard for about 15 minutes and reconnect it. It's a small lithium battery.
SOURCE: HP Pavilion dv2500 - FTB
The troubleshooting you have done seems to be fine. It does not seem to be a problem with the power supply,cord or battery.Did you try a hard reset. If there is a reset button on the bottom of your laptop, you might want to try pressing that with laptop plugged in, not plugged in, with battery, without battery and different combinations thereof.
If this does not work or you don't have a reset button read on.
Before assuming it's the motherboard, there is one other possibility. There is a part called a PCA switch. It is possible this switch has gone bad or a plug might have come loose.
If you are comfortable with doing your own work, you can obtain a repair manual for your laptop online. Within this manual, it should explain what is involved in replacing this part. It is really not too complicated.
It does not sound like a hard drive problem simply because it doesn't seem to be getting power to any other part of the laptop.
You can try these steps.
Regards
SOURCE: My fujitsu c2330 was working fine and the last
i believe your life book went into standby mode. i have heard nightmare stories about standby mode. when the computer enters a low power state, it keeps the ram refreshed and the cmos active.,all settings are avaliable. when powered back up all is restored quickly and ithout waiting for device to fully load. thus if the device had anything swicthed example the wifi card button, to off when it was on in standbye mode their are numerious iussues that will result. best way to fix boot into safemode and see if theirs anyway to shutdown and reboot into safemode., if the option is their for use the last settings that worked. thense4lect i, only good after 1 boot failed. then its no good.
take it back where you bought it
for exchange or refund.
I bought it as econd hand... I assume the warranty is non transferrable. And even at that I know for a fact that it's more than a year old. It's not old but at least a year. I guess I'll just trash it.
