Question about Sony Audio Players & Recorders
How do I get a Sony Receiver STN DN-1080 out of DEMO Mode?
When I plug it into the wall the receiver automatically turns on in DEMO mode. Nothing else can be changed except for the volume dial. I have tried every resource I know to figure this out including calling Sony. No one has an answer.
Posted by James Azevedo on
RudeRude
    Master:
  • Sony Master
  • 526 Answers
What need to do is go into the settings menu and find the section on sorting it out or you could do a factory reset. That should get you sorted..
Posted on Mar 06, 2021
  • James Azevedo
    James Azevedo Mar 08, 2021
    It won't let me do anything once I plug it in. It automatically turns on in DEMO mode. The only thing I can do aside from plugging it in is adjust the volume.
Turn off demo mode on sony str
Go into the settings and select Demo Mode OFF
No radio rception,player is in demo mode
1. Press and hold the SETUP button for at least 3
seconds.
2 Press the f UP or g DN button to select the
"DEMO" mode.
3 Press the BAND button to turn on or off the DEMO
mode.
Each press toggles between "DEMO ON" and "DEMO
OFF."
If no buttons are pressed 30 seconds after the DEMO
mode is turned ON. The DEMO mode then begins.
NOTE
The initial setting at the factory is "DEMO ON."
4 Press the SETUP button again to return to normal
operation
How can I get Dynex TV out of "protection mode"?
the protected mode kicks in when there is a safety issue with the receiver. This usually comes from an overload to the system via a short in the system or perhaps a surge in power. Your receiver shuts down, and you'll need to shut the entire system down to fix it.
In some older homes, some of the wiring doesn't deliver the "cleanest" power, delivering minor power surges to the items you plug directly into the wall. If your receiver is plugged directly into the wall, purchase a surge protector to stop this
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYa9W0Mi
God bless you
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYZm8THG
How to force pioneer u310bt gps to search for satellites
The GPS should automatically search for satellites unless it is in Demo or Simulation mode.
Be sure to turn of the Demo mode.
Use the Navigation screen and touch the Demo button to turn on or off the mode.
1helpful
I have kenwood XD-A75 stereo,and i have not been able to remove the demo mode after i try to cancle it it just comes back after i turn the power on, i read the manual but nothing. is there another step i...
When the AC cord is first plugged into the unit, the unit will go into demo mode. To cancel demonstration mode press the Ex.Bass/Demo button. This button is on the front of the receiver, left side towards the top. The demo mode will be cancelled and the receiver will be in low power consumption mode. It may appear that the unit is off because the display will disappear but the radio is in fact on. When the radio is on you can also adjust the bass with the Ex.Bass/Demo button as well.
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
2helpful
2answers
Reciever is stuck in DEMO Mode how do I get out of it? Using the power off procedure has no effect. Thanks in advance!
Hi Carlito,
Not sure what method you are using to turn off the demo mode, try this
  1. disconnect the unit from the power
  2. plug the unit back in again after 5 mins
  3. whilst the display indicates "now demonstration mode" press the on/off button on the unit
I got this procedure from the owners manual, so should work. If it does not, then try holding the power button in for 5 secs to do a software reset.
Good luck, get back to me here is you still have problems. If you need, you can download a PDF of the manual from here.
regards
Graeme
Can't get it out of Demo mode
hi sir,
if all the buttons dont work when pressing it, maybe there is a lost connection of the buttons or buttons are shorted. try to check it out...
hope it can help...
2answers
Stuck in demo mode
Unit does not have a demo mode that I can find or have ever seen and I have been using mine for over 4 years.
Turn it off and reboot.
Top Sony Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
