Question about Samsung Computers & Internet
I have a Samsung windows 7 when I on my system it showing me operating system not found no keys are functioning for me to set it up what should I do please?
Posted by SARKIN NOMA KARMO on
  • 2 more comments
  • Larry Ng
    Larry Ng Mar 05, 2021
    no model told just the maker SAM.
    this is very common,
    the causes are mostly 2 fold,
    the batteries in the PC are bad.
    or the HDD is dead.
    are you asking how to learn the art of PC repair or why not take it to a PC repair shop.
    the screen is not dead
    the BIOS is not dead, you get post errors so is NOT DEAD
    only windows 7 is dead,
    and if the RTC coin cell inside goes dead
    the PC can not find the boot drive.
    so tells you no boot found. for just that reason, a bad coin cell.
    the BIOS keys work but you do not know them.nor can I tell you them due to no model told.
    google told me F2 is the key
    so power on and hammer F2 key
    see BIOS now? if yes is date correct?
    time and date must be correct in BIOS
    if way off that means the battery is dead.
  • Larry Ng
    if the coin cell is not dead, over 2.9v is good. then we test the HDD next.
    no OS on earth can run on a bad HDD
    so that is next,. (lots of tests there are)
    after all it's only a computer..
  • Anonymous Mar 08, 2021
    1: bad batteries all. both.
    2: kids played with BIOS and now a wreck.
    3: HDD now bad, as all are this old.
    1,2,3,
    why not ask any PC shop to test it and find the cause.
    if the PC has bad hardware we must fix that first. like car with 4 flat tires, first.
    then we test the HDD next (hardware that too)
    if HDD is ok and smart tests pass
    we replace all dead batteries next. weak or dead, or far far far worse a 0volt shorted battery, the RTC battery is bad I bet.
    then load windows first. your call what windows.
tcconsult
    New Friend:
  • 29 Answers
Do you have a recovery CD or DVD that came with the unit? If so, try booting up from the cd and perhaps it will let you run a repair? Of if you can get into the BIOS of the unit, and that may be hard if your keyboard doesn't work, see if there's an option to activate the keyboard before bootup. Another idea is plug an external USB keyboard in and see if that works after a reboot.
Posted on Mar 08, 2021
5 Related Answers
Anonymous
SOURCE: function key doesn`t work with windows 7 installed
My Vaio model is VGN-FS840 and after I formatted by laptop, my function key is not working, what shall I do to make it run? Can I download the driver? is it available in websites?
Posted on Sep 24, 2010
Tri3mast
Robert Taylor
  • 747 Answers
SOURCE: We note the operating system
Windows XP is an older version Windows 7 is a new version So yes Windows 7 is compatible.
You can back up in technology but you can't go ahead.
Posted on Jan 17, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: I purchased a compaq CQ62
if its only 5 months old you should still have warranty on it you should contact the place of purchase before doing anything
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
try blowing the dust from the fan and your laptop computer computer dust will cause static which can cause a computer to overheat and many unforseen problems also
you could get a usb laptop cooling pad they are very cheap and your laptop will love you for it
hope this helps
Posted on Mar 18, 2011
Anonymous
  • 44 Answers
SOURCE: i have compaq presario cq42
Now New Model Laptops Come with Fn+Multimedia Keys this Model Laptop Same Tpye. If You Change Settings Goto Bios Change "Fn Keys Behaviour" menu. OR Using Without Pressing Fn Key only Press Drictly Fn keys. Again Same Problem Please Install Quick Lanuch Button Driver (this software Working Properly Please Install .Net Frame Work First) Form Compaq Site under Software - Soultion Category (Select Proper OS) http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&os=4062&product=4308201&sw_lang=&#N600
Posted on May 07, 2011
mmnhltm
Mamoon Haltam
  • 695 Answers
SOURCE: samsung r519 operating system not found windows 7
PROBLEMS IN HARD RIVE DRIVERS
RE INSTALL WINDOWS 7 AGAIN
Posted on May 11, 2011
Windows 10. How to force windows explorer background to be set by themes as it is in windows 7 ??
Hii,
You can contact to Microsoft Officials or Experts at 1800-102-1100.
& if you want to contact Technicians for Microsoft, you can contact on 1800-626-1046.
Thank You.
Nov 10, 2016 | Microsoft Computers & Internet
Fix windows 7 home updates download
go to uninstall programs in the settings menu and tick the show system updates option
. Remove the last update and then try again
Aug 16, 2016 | Microsoft Windows 7 Home Premium 64BIT...
How can i adjust the brightness of my laptop aside from using function keys.i cannot adjust it even using function keys..it doesn't work.
You can access this setting from the control panel as well. The steps may vary depending on your operating system.
1. Go to the Start Menu 2. Access the Control Panel 3. Select the Display 4. Browse the window for the Adjust the brightness options (For example, I am running Windows 7 and it is on the left side of the window)
Mar 17, 2011 | Samsung Computers & Internet
Rhow to install window 7 with a cd rom give me steps
put your Win. 7 DVD in Rom Drive then restart your system -- when your screen shows the options to press F2 then press it then go to boot settings then put your rom drive to 1st boot device and hard drive as 2n boot device -- then press F10 and ENTER. then your system will restarted. then after few seconds your displays shows that "Press any key to boot from CD/DVD...." then press any key to go to setup then follow the steps and install Windows 7 and enjoy it.
Feb 11, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have gprs settings on my mobile. I wanted to connect my nokia 5130 to laptop which having windows 7 ultimate to open internet connection in laptop. But after making dial up connection, it is showing...
When trying to connect to your laptop with windows 7 as an operating system, trust me the problem is not from the phone, it is the operating system that is not allowing such function.
Try to use the phone on another operating system to see if it works fine, then you will be able to tell if it is from the phone or the operating system.
Windows 7 does not allow plenty of functions so do not be surprised if it is the cause of you not being able to browse on your laptop using your phone.
Take care and good luck
Oct 14, 2010 | Nokia 5130 Cellular Phone
I have got a laptop which is running windows 7 ultimate. last night i compressed c drive of my laptop which contains the operating system. in morning when i started the laptop it showed message "BOOTMGR...
Try to boot your Windows 7 bootable DVD and check for errors and then restart. Keep Tapping F8 until you see the safemode options. Then get into the safemode and goto command prompt type the chkdsk c:/r after that a process completes and then try typing fixboot thats it. It will work. Let me know if the problem cant be resolved or if you have any doubt.
Aug 31, 2010 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
