Question about Philips Televison & Video
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Posted on Dec 09, 2008
SOURCE: Vizio Code for Philips Universal Remote
Think 0002 will work. If not a GOLDSTAR code should work,
try them.
Posted on Dec 15, 2008
SOURCE: I need the dynex tv code for a comcast remote control
Try 10463, or the Emerson tv code.
Posted on Apr 09, 2009
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red
indicator stays on and release button
3: press and quickly release what
you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly
untill your t.v changes channels(up to 300 times) if you over shoot the
channel change press down til it changes again.
5: press and release
MUTE to install the code.
Posted on Jul 17, 2009
Sep 03, 2012 | Dynex DX-LTDVD19 19 in. LCD TV
Jun 28, 2012 | Universal Remote Control GE174Universal...
Apr 01, 2012 | Dynex Televison & Video
Mar 22, 2012 | Jensen JR300 Remote Control
Feb 27, 2009 | Dynex DXR24TV 24" TV
Nov 04, 2007 | Televison & Video
Jan 15, 2021 | Philips Televison & Video
