SOURCE: locate exploded drawing of poulan chain saw
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
SOURCE: need instruction manual for meridian color magellan p/n 800482-01
Yahoo's user group called Magellan_Meridian has manuals and great information on all models.
SOURCE: 455 rancher will not produce oil for the chain.
Also make sure that where the oil is pumped against the side of the bar that the oil port (little hole) that feeds oil into the bar's slot is clear. Mine would go through a tank of oil with each tank of gas, but the chain wasn't getting oiled until I cleaned out this little hole.
SOURCE: i need parts breakdown lists for jack hammer
Follow these links and you can get the breakdowns for both:
http://www.crowdersupply.com/116.htm
http://www.crowdersupply.com/117.htm
Crowder Supply also has a lot of other breakdowns you can look through.
SOURCE: milwaukee c 18 dd model parts list/manual
here is a site where you can see the schematics and buy the parts I hope
it works for you:
http://www.toolpartsdirect.com/milwaukee/milwaukee-7.html
if it does, don't forget to rate me
thx
