Why would my lubed Proform Crosswalk 480 treadmill abruptly stop after 30 secs? I have lubed/adjusted the belt, cleaned the motor, and blown the dust out with no luck.
see the video attached, lube TOO the rollers bearing front +back. see the video how to adjust the deck belt.God bless you However if finally the problem persist, test the input voltage motor see my personal TIPS, if there are Voltage at the terminals, the motor is faulty. Measure the output Voltage from the control board for to input to the Motor, if there are NOT voltage from output the control BOARD is faulty, replace.
1) you must LUBE THIS Happen because the machine has special design for to protect the electronic system. Maybe you have NOW WORN deck belt, time to replace. 2) Lube the rollers bearing too 3) test the bearing for the main motor. and repair
1) LUBE The DECK BELT VERY WELL, see the video and proceed with common sense. this happen because the lack of maintenance according the instr. manual. This happen for to protect the electronic system.Maybe you have worn deck belt, and need replace, but first LUBE.
2) lube THE ROLLERS BEARING too, very well
3) Test the input voltage motor, if there are The motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
1) LUBE the DECK BELT, this happen for protect the electronic system, shut down. Maybe you have a WORN deck, to due the lack of maintenance according the schedule. 2) LUBE the rollers bearing too, very IMPORTANT. see the video. God bless you
see the diagram, and RUN the software calibration for diagnose and troubleshooting. lube the gear and racking from elevation motor, clean, and tigh any wires connectors:
Dear Sir: LUBE the deck belt, is lack of maintenance, maybe you have to change the deck belt, this produce enough friction and shut down the machine for to protect the electronic system.
2) lube THE ROLLERS bearing , according with the maintenance schedule.
3) Clean any EXCESS of wax, and LUBE very well. 4) Test the input motor if there voltage the motor need repair.
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty. Try if you can RUN the software calibration for diagnose and troubleshooting. sincerely. God bless you.
