Question about JVC Televison & Video
I have just changed the bulb of my JVC HD Z56RX5A. But the picture is dark. Everything else I fine. Any ideas what the problem is, please!
Posted by Sofia Petrova on
    Top Expert:
  • JVC Master
  • 76,582 Answers
After a lamp replacement, you should perform a lamp time reset. Did you done that? If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Posted on Mar 06, 2021
5 Related Answers
Anonymous
  • 520 Answers
SOURCE: Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
Posted on Feb 21, 2008
Anonymous
SOURCE: JVC HD-52G786 shuts off
Do you have your TV plugged directly into the wall? You cannot plug into a power strip, it needs its own direct power source. Also, I have heard that there can be electrical problems inside. I have this same model, I love it, picture and sound. I just replaced the bulb for the first time last night. It was a little premature to replace it now but I know what caused it. I bought a new bulb and it works like a gem. If you ever need to change the bulb do it yourself. It takes maybe 2 minutes. The bulb looks like the Flux Copassitor and all you do is remove the door in the back on the side. Unscrew the the 2 screws that hold the bulb in and just pull out. When you put the new one in make sure you do NOT touch the glass on the new lamp. Just slid it in and screw the 2 screws back in and make sure the door is closed and tight. My uncle had a service guy do his and he got raked for 5-$600, The bulb costs about $200. Should last about 5-6 years at a rate of 5-6 hours of TV on time. Hope this helped. If not, sorry, but at least you know how to change the bulb. Good Luck!!!
Posted on Apr 08, 2008
Repo Man
  • 20 Answers
SOURCE: Everything functions fine but the picture is very dark
I think you answered your own question. You have a rear projection television. It sounds like the lamp is not functioning correctly.
All projection lamps have a recommended life measured in hours. I checked the web and this model appears to be about 3 or 4 years old. from 2005 or so.
The lamp in my Samsung is rated at 3000 to 5000 hours, I had 12,800 when the service Tech was in changing another part.
3 or 4 years running one lamp is a good run. This is why DLP has lost favor for table top sets, Most are LCD or Plasma now.
Check you TV for it's lamp model and them shop around allot. Lamps are not cheap however some suppliers offer much better pricing that others. Care should be taken to make sure you order and purchase real replacement lamp and not a clone / compatible model. Original parts should produce the picture you are expecting
Posted on Jul 08, 2009
Jim Krause
  • 1779 Answers
SOURCE: JVC HD-61Z456 Television to dark
Most likely a bad Polarizer within the light engine of which you cannot buy. The entire light engine would have to be re-built or replaced and they usually start around $600.00....
Posted on Jul 09, 2009
Anonymous
SOURCE: Lamp and Power lights blinking fast and no picture...
hi mach500..We just had the same problem. Did you find out if it could be the fan?
Thanks
Posted on Aug 28, 2009
JVC HD-52G886 HDTV Television screen is dark
usually it is the lamp this set uses, has it been replaced or is over 2 years old?
Oct 29, 2012 | JVC HD-52G886 52" Rear Projection HDTV
I have jvc replaced bulb but picture is still very dark if not bulb then whay would cause the dark picture not bright or vibrant
Problem could be in the Light Engine and it may need to be replaced. which is also known as the optical Engine PN# TSCOP7A-SAA
Oct 08, 2012 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-61Z886 61 picture is dark. Is this fixable.
Could be dust in your light engine or build up on your mirrors.
Jun 21, 2012 | JVC HD-61Z886 61" Rear Projection HDTV
The Picture on my HD-52G886 Model is really kind of dark I can still see the picture and sound is fine but a little to Dark when I try to brighten it then its really dull white.
Changing the contrast will also help brighten your screen. For best results, try changing the contrast and the brightness, to find the perfect combination for your needs.
Jul 19, 2011 | JVC HD-52G886 52" Rear Projection HDTV
My jvc model #hd-61z456 is working at too dark of a picture. I have replaced the light bulb twice and have reset the picture setting to factory setting and I don't know what else to do can you help me....
Both times bulbs was replaced it lasted 1 1/2 or 2 years right?Use tv on like 4 or 5 hours a day?That the avervage life span of a projection bulb.Try to buy an original JVC pojection bulb last little longer.
Sep 12, 2010 | JVC HD-61Z456 Television
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Jvc 52z575 dark TV
The life estimate for a bulb is about 5000 hours, and if the bulb is dieing before that is very obvious you have another issue on the TV
That Could be a temperature problem, like a cooling system is failing (usually the is two fan around that) or a lot of dust in the cooling system. another one could be temp sensor also maybe failing and is not sensing high temperatures and is no turning off the TV
Also make sure you have enough ventilation in the back of the TV
Hope this give you a better idea of the problem
thanks
Apr 23, 2009 | JVC AV-48WP30 48" Rear Projection...
No picture.
The lamp is turned on by a high voltage ballast, very similar to the ones in your fluorsecent light fixtures. Your ballast is starting to fail. You should have your TV serviced by a JVC authorized service center because they have the training to deal with this issue. Waiting until it fails could very likely cause more servere damage especially if it fails shorted then the power supply will need to be replaced as well.
Mar 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
Top JVC Televison & Video Experts
matt martin
matt martin
Demonic-2011
Demonic-2011
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
