Question about Samsung Av-r730 A/v Surround Receiver Receiver Only Working Perfectly
Samsung AV-R730 receiver has no sound
No speaker response at all
Posted by William Schilling on
Tom Chichester
    Top Expert:
  • Samsung Master
  • 61,703 Answers
Receiver could be in protect mode or suffering from failure of amplifier chain component(s)
Posted on Apr 08, 2021
5 Related Answers
Mergatroid
  • 286 Answers
SOURCE: My Samsung HT-AS720ST (AV-R720) surround sound receiver started
The problem is caused by the PULSUS PS9829B digital audio processor. We ordered it in from a Samsung authorized service centre.
Problem is now solved. Unit works perfectly. If you have never tried working with surface-mount ICs I would skip it if I were you. This IC has over 100 pins on it. However the part is available from Samsung. Print this comment and take it to your locat service centre along with your receiver. They should be able to repair the board unless they are wussies and cannot do surface-mount work.
Posted on Oct 21, 2010
Anonymous
  • 6 Answers
SOURCE: No HDMI output on Samsung AV-R730 AV receiver
more info please????
Posted on Jul 13, 2011
Priyesh Vadher
  • 547 Answers
SOURCE: how do i hard reset my samsung sch-r730
Try this code *2767*3855#
Posted on Jun 21, 2012
Steve K
  • 1054 Answers
SOURCE: my pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Posted on Mar 14, 2013
francisco abreu
  • 7 Answers
SOURCE: TV has low sound output through right speaker of stereo receiver
SAMSUNG DLP SOLUTION. I fix a similar model Samsung HLS model. I added capacitors to each of the three dc to dc converters on the main board. You can download the data sheet for ic212 (MP1583dn). Main board is where all the external connections are made from outside). Remove the metal cover which covers one third of the main PC board. To test this fix, only one of the dc to dc converter needs a capacitor. Location IC 212 is the dc to dc converter of major interest and will fix all problems. Add a capacitor on top of capacitor presently located at location c217 as printed on the pc board. be careful with polarity of capators. Do not place this capacitor on the ic pins of MP1583dn. The voltage at location c217 should be STB 3.3 volt. You could also place the capacitor at location BD212 (+3.3) and ground, instead of on top of capacitor if you need more clearance. BD214 and ground for converter ic 213 or on top of capacitor C236. At capacitor C212 for ic211 or at BD210 to ground. The value should be 33 uf or more, anything less will have limited fix. I would not pass 60 uf. I place a 33 uf capacitor with a working voltage of 35. This fix not only work for popping noises from speaker, but it also improve the colors. Solder with caution, leave no speck of solder behind. good luck. search the web for free service manual.
Posted on Apr 30, 2013
Samsung av r730 looses all presets when powered off?
That is unusual. It seems there is need to update the firmware for that Samsung and perhaps this adjustment may lock in the settings. Call the manufacturer for directions on how to update the device.
Jan 12, 2018 | Samsung Computers & Internet
My Samsung AV-R720 receiver has Cracking sound in front right speaker when turn on. Cracking sound last 300 seconds and stop. But after I turn it off 10 mins to turn it on and cracking comes again.
Hi try spraying the volume control pot with. Electronic cleaner solvent u will have to open the receiver to spray the pot ....u can buy the spray on E,/BAY ......GOOD LUCK
Jun 11, 2016 | Samsung Av-r720 7.1 Av Hdmi Dtv Receiver
Surround sound unit turns off right after I turn the system on and can not get it to stay on !!! I left for vacation came back and now the unit will not come on for more than 4-6 seconds ! My friend said...
Hi Ninh,
I had a similar problem with my stereo receiver not long ago. The problem ended up being a short in one of the speakers. If your speakers are powered separately from the receiver, it might be that one of them was damaged due to the storm. The short would cause the amplifier to shut down as soon as the speakers are turned on.
The easiest way to check this is to disconnect all the speakers, turn the surround sound on and then reconnect them one at a time to find which speaker is causing the problem.
Hope that helps.
Jeff at Remotes.com
Apr 14, 2017 | Televison & Video
Samsung r730 laptop stuck in hibernate
To be honest i would pull the battery, a little unusual but it sounds like you are stuck. if that doesnt work after restart try and check connections
Apr 24, 2013 | Samsung R730 Notebook
AV-R730 stuck in headphone mode?
Try a quick blast of compressed air into the headphone jack area. Worked great for me.
Apr 14, 2013 | Samsung Av-r730 A/v Surround Receiver...
Samsung reciever protection error
There is a internal problem. Will have to be taken in for repair,
Dec 01, 2012 | Samsung Av-r730 A/v Surround Receiver...
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
I have a RX-V461 AV Receiver for my Samsung HDTV.
I don't have manual here, but try to go to Setup menu / Speaker setup / Manual Setup / Config and check if rear speakers are NOT set to None.
Nov 19, 2008 | Yamaha RX-V461 AV Receiver
Nakamichi AV-7 5.1
in this case the centre speakers are the main route to the sound. 5.1 is for movies, where the centre speaer takes predcedence.
Aug 29, 2008 | Nakamichi AV-7 Receiver
Samsung Av-r730 A/v Surround Receiver Receiver Only Working Perfectly Logo
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
