Televison & Video Logo
Question about Toshiba Televison & Video
I have a Toshiba DVR620KU DVD Recorder/VCR which is 8 years old and the power will not stay on. The power stays on for 10-15 seconds before shutting off. Any idea what could be wrong with unit?
Posted by Irvin Spindler on
David Spradling
    Top Expert:
  • Toshiba Master
  • 13,399 Answers
Bad power supply
Posted on Apr 23, 2021
    Top Expert:
  • Toshiba Master
  • 76,851 Answers
Sounds like some thing short circuit at its circuit board. Short circuit protection activates, as the set is switched on. Contact any service technician to check and find out the fault. This is not a user repairable fault. If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Posted on Mar 06, 2021
5 Related Answers
Anonymous
SOURCE: toshiba md20p1c tv power won't stay on
The problem is Q401. Change it. It is a 2SC1624 but a 2SC1018 will also work. This solution will work for other Toshiba P combo units.
Posted on Mar 14, 2008
Anonymous
SOURCE: lg dvd drawer opens by itself and wont stay closed
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Posted on Jan 28, 2009
Clyde Hanson
  • 221 Answers
SOURCE: Magnavox VCR/DVD recorder model ZV450mw8.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Posted on Feb 03, 2009
Anonymous
SOURCE: magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
Try better quality VHS tapes or 6-hour tapes instead of 8-hour ones. I had this problem myself when I used 8 hour tapes, but haven't had any problems with the 6-hour ones.
Posted on May 17, 2009
Anonymous
  • 4 Answers
SOURCE: toshiba boots up power light stays on and shuts down, bad m/b ?
I own a Laptop Toshiba Satellite A75-S2131.
This series have a problem with the cooling flow to the processor.
The processor overheats and the laptop shuts down.To solve this particular problem you must tear down the laptop and clean up the processor heatsink (you will find it totally plugged or partially dirty).
Find in the internet the step by step instructions (with photos) for dismantling this laptop. Do not forget to apply thermal paste between processor & heatsink.
I hope this solution helps.
Posted by MCampos
Posted on May 31, 2009
How can I record a 2 hour tape to a 8.5GB DVD +R DL on my Toshiba DVR620KU.
The Toshiba DVR620KU does not support dual-layer discs. See this page from ManualsLib, https://www.manualslib.com/manual/203807/Toshiba-Dvr620ku.html?page=9#manual . There is also a list of known compatible DVD discs for use with the recording function of the DVD rewriter/VCR on the next page. You should be able to dub a 2 hour (120 minute) tape to a DVD+R (4.7GB) disc. (I'll assume there is no copy protection on the tape.)
Look at page 50 and 51 for the directions for dubbing. Page 50 is here https://www.manualslib.com/manual/203807/Toshiba-Dvr620ku.html?page=50#manual . You'll want to focus on the directions in the left column. Note the section about auto-tracking of the VCR tape. Make sure to correctly indicate that the VCR is the source. Then after dubbing, finalize your disc to watch it on other DVD players.
I hope this helps.
My vcr-dvd comes on for about 7----12 seconds & then makes a rapid clicking sound & shuts off.
I would have a look at the sledge that the Lazer sits on to see if there is any plastic bits broken around where it is or itself. That might explain the clicking noise.
3answers
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
I have a Toshiba DVR620ku DVD/VCR combo. I have the Format Mode properly set to "Video mode." I put in a new, unformatted DVD-R, and the player should format the DVD, but it doesn't. I click...
My brother had the same problem. Toshiba tech support said the disc was already formatted, so the DVD MENU option would not be available. He went straight to dubbing and recorded to the disc. After recording, the DVD MENU option was then available. He thought the disc was not formatted since it was straight out of the package and he always had to format other new discs. Perhaps your disc was actually already formatted?
DVD drawer won't stay closed
the open button could be shorted meaning the unit is constantly being told to open its tray i think its worth having looked at and i think your sons off the hook dvds are pritty hard for kids to muck up unlike the older vcr you would no belive the things kids would put in them best one i ever saw was a weat bix and a slice of toast.
good luck
1helpful
Toshiba DVR620KU error E 25 cannot put VHS onto DVDs
Probably copy protection.
You can remove it with a Grex or similar
device.
VCR problems
My solution was to call my warranty company. I'm sending it in and getting my money back. They said it would cost more to fix it than I paid for it.
2helpful
2answers
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
