Question about Samsung Televison & Video
It is a possible lightening issue and TV is not turning On. Power supply output all other voltage 12.5, 5, and 3.5 volts for each output pin of all connectors. Only this pin FIAL output 0.9 volts that looks wrong to me. Expert please guide.
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Posted on Mar 06, 2021
SOURCE: Type of power supply and what where is the +/- 5v or color coding for the 4 pin connector?
Dhen: This monitor uses a special Power Adapter as shown... Also the Pin designation is from the NOTCHED PART BEING ON TOP: NOTCH U +V O O +V GND O O GND SithPitt
Posted on Jul 04, 2007
SOURCE: LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Posted on Nov 17, 2008
SOURCE: FAULTY POWER SUPPLY FOR LITE ON PS -5251-2DS
when connected the AC power , no DC voltage reading from the p.s.
what to do?
how can i turn it on?
Posted on Nov 24, 2008
SOURCE: where do you buy the 10 pin connector
I used a computer power cable (the one that plugs into your IDE HDD) and soldered the male end onto the circuit board. Sorted :)
Posted on Jul 28, 2009
SOURCE: What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Posted on Aug 08, 2010
Jul 09, 2018 | LG Televison & Video
Dec 04, 2016 | Televison & Video
Aug 08, 2016 | Samsung Televison & Video
Nov 15, 2015 | Vizio Televison & Video
Apr 08, 2015 | Vizio VX42L 42 in. LCD TV
May 27, 2013 | Samsung Televison & Video
Courtesy of Delphi Product and Service Solutions.
I hope this helps!
Mar 26, 2013 | GMC Sierra Cars & Trucks
Mar 02, 2017 | LG Flatron Computers & Internet
May 23, 2012 | Cars & Trucks
Jan 27, 2021 | Samsung Televison & Video
