Question about Freezers
How old is an upright freezer serial number MAF218087R.
Posted by Barbara Martin on
STEVE
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 38,274 Answers
We have no way of knowing that
Posted on Mar 03, 2021
Where can I get a freezer door key for Kenmore upright freezer model 39153
Locksmith.....just take the model number and serial number to them. If they can't, most likely have to be from the manufacture.
Oct 07, 2015 | Kenmore Freezers
Lost manual for my Fridgeidare upright freezer 20.5 with the controls on outside. what does 0F mean. and if I need to set it ,we just moved how do I set it?
Hey friend, thanks for your post!
From my understanding you have recently moved your Frigidaire freezer and it is now displaying the "OF". Normally, that stands for off you should be able to press the "Up" or "Down" arrow three times within five seconds to start your compressor. If you still need a copy of your manual could you provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I hope this has been helpful. -Matt
Oct 11, 2014 | Frigidaire FKFH21F7HW 20.5 Cu. Ft. Upright...
Freezer age and kwh usage for kenmore 2722
go here,put the name,model and serial numbers in and it will tell you how old any appliance is.
http://www.appliance411.com/service/date-code.php
Jul 10, 2013 | Kenmore Freezers
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
Yellow power light keeps blinking on upright freezer even after replacing 9V battery and temperature is good.Have waited about 16 hours for freezer to stabilize. Problem?
If its the power light, and not a temperature alarm light, it may only indicate that there was a power loss, perhaps you had a brown out or power surge. you say the temps are good, any chance you have ice cream or bread in freezer? if its above 10° F they will be first to get soft, rather than firm. If I had the model # as it is on the model number tag, the only tag usually on the inside or possible on the outside, of the unit, that will have the model and serial number both listed.
Mar 24, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Taking out trays for cleaning
Usually the holes are deeper than they appear in the side walls. Lift the shelves just a hair and then push them left...the right side should now be outside the hole and able to be moved upward until left side clears.
Reverse this process to reinsert. Good Luck.
Aug 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Dan Webster
Dan Webster
Are you a Freezer Expert? Answer questions, earn points and help others
