Question about Samsung Televison & Video
Sounds like main board fault. Contact the authorized service center for Samsung. If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Posted on Mar 06, 2021
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on. If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Posted on Jul 01, 2009
SOURCE: vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
Posted on Sep 05, 2009
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
SOURCE: Screen marks on my samsung lcd tv.
Sorry not a solution just confirmation of similar fault on a Samsung 32" . I to have this problem which appears to be getting worse . started with 1 mark and has now spread to about 20% of the screen albiet numerous marks. It appeared after 18months to 2 years after purchase in 2006 so now 4 years old. I've accepted there's nothing to be done and out of warranty. Problem is purchase a new set Samsung or another. But will I have the same problem 2 years after??
Posted on Dec 07, 2009
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Jan 28, 2016 | Samsung Televison & Video
Dec 16, 2015 | Televison & Video
Sep 06, 2012 | Samsung Televison & Video
Feb 10, 2018 | Televison & Video
Jul 02, 2011 | Sanyo DP19649 LCD TV
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
Feb 27, 2010 | Samsung PS50Q91HD 50 in. HD-Ready Plasma...
Sep 13, 2009 | Televison & Video
