Question about Sony Televison & Video
Sony bravia lcd tv model no. Klv-32ex310 has small horizontal stripes passing through the picture is coming but the lines are visible
Posted by Saidi Njoroge on
    Top Expert:
  • Sony Master
  • 76,582 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter
Posted on Mar 03, 2021
5 Related Answers
Anonymous
  • 1226 Answers
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Posted on Apr 08, 2008
Anonymous
SOURCE: Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Posted on Oct 08, 2008
leusnerdus
Leonardo Hernandez
  • 54 Answers
SOURCE: looking for a sony bravia klv-46x350a lcd spare
Usually the LCD panel cost is around 80% of total TV price. Look for it in a center of service.
Posted on Apr 20, 2010
Anonymous
  • 713 Answers
SOURCE: We have a Sony Bravia lcd tv model KLV-S40A10 - no power
Hi,the problem is from the fuse in the tv,it's blown and it's a means of in-built security against power fluctuations from damaging the unit,so the solution is to replace the fuse of the TV to restore your unit back to a normal working condition.
Be cool.
Posted on Jun 13, 2010
bobatnet0729
bobatnet0729
SOURCE: sony bravia klv-32t400a lcd tv
YOU MIGHT HAVE A GOOD CHANCE BY CALLING 1-800-222-7669 IF TED IS STILL EMPLOYED THERE, HE'LL BE ABLE TO GET YOU ON TRACK, GOOD LUCK BOB G.
Posted on Feb 03, 2012
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
Sony bravia 32ex310
Sony Bravia klv-32ex310
horizontal lines and ghosting .
probably panel problem
there are two circuited left right connected via non removable cable on lower side.
how to correct this issue
Apr 16, 2013 | Sony BRAVIA Televison & Video
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Dec 07, 2012 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Sony Bravia LCD TV. There's a horizontal black line appearing just below the center of the screen. Have observed it's getting longer.
it may be the display panel especially if the line is black.
Some tests are needed and maybe a board swapped etc but if it turns out to be the Panel the part costs more than the set did when new===fatal.
May 26, 2012 | Sony Televison & Video
My sony bravia model nos.klv-26S400A IN5 its lcd
I don't have a listing for your exact model, but a similar one has its LCD panel costing over $600 net. Check with a local servicer for parts availablility as the model I used has the panel no longer available. It is possible that a replacement panel won't be available for you either.
Hope this helps a bit,
Dan
Apr 29, 2010 | Sony BRAVIA KLV26S200 26 in. LCD TV
Looking for a sony bravia klv-46x350a lcd spare
Apr 20, 2010 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
My Sony Bravia KLV-40U100M has audio but the screen is black. No picture. Could it be the lamp? The unit is only a little over 2 years old
No,this tv a LCD not a DLP.The LCD inverter board is dead.Must replaced to get picture back.The board is usally a long board.Tries Shopjimmy.com,Ebay.com to buy the board.
Jan 15, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony Bravia KVL-V40A10 - pixelated lines top and bottom of screen
Are these lines visible regardless of what device (DVD player, cable box) you are watching?  If so, then yes, it appears the LCD panel is failing.  If you only see the lines watching one device, it could be the cable/wire or the device itself.  Now it can also be the related input jacks too so connect the device to another input to be sure.
Mar 24, 2009 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Apr 08, 2008 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Open Questions:
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
