Question about Packard Bell Computers & Internet
I have a packard bell one two L17623 UK It has lost bios settings so needs CMOS battery replacing. I have stripped it down but there is no sign of a CMOS battery anywhere on the motherboard
Posted by William Richards on
  • Larry Ng
    Larry Ng Mar 03, 2021
    the mobo has 2 sides. all do. top/bottom
    and AIO, all on one PC.
    or ask them?
    https://www.packardbell.com/pb/en/GB/con...
    RTC is CR2032 silver colored coin cell.
    some are next to CPU,
    look carefully
    or tell full PC part numer, with Pw-uxx
    there is U code there, and matters.
    not told by you seen on the service tag.
Relax
    Top Expert:
  • Packard Bell Master
  • 33,847 Answers
Take the motherboard out as it is on the underside of the motherboard.
Posted on Mar 03, 2021
Testimonial: "Many thanks will try that as had not thought of that :)"
Old Packard Bell Easynote R4650. Where is the CMOS battery?
Hi Brian.
not sure if this will help you out.
go to this youtube link might be of help to you.
Packard Bell Easynote R4650 cmos battery YouTube
Jul 04, 2018 | Packard Bell Computers & Internet
What is CMOS Baterry
It is battery on your motherboard that keeps alive basic computer settings including the clock. Removing the battery will reset all the settings in BIOS to default.
Feb 07, 2013 | Packard Bell iMedia SL 9553 (P660401806)...
I have a challenge for you experts.A friend ask me to see if I could repair his computer he was given by his mum that was in the atic for at least 6 month (Packard bell i design 190) I put all the cables...
WOW, this sounds so familiar, try changing the CMOS battery, I got the same exact error mess in a old packard bell i refurbished for a friend and a simple change of the cmos batter solved the issue, it even let me install xp with not problem,, its worth a try.... :)
Sep 04, 2011 | Computers & Internet
I have locked myself out of my Packard Bell MV35-202 with a bios password
If you have problems with your BIOS password, one thign you can do is to remove the CMOS battery from the compute, to reset the BIOS password.
Cheers!!
Sep 02, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
I forgot my bios password of my laptop packard bell s4 easynote. I want to remove the cmos battery but i do not know t o open my laptop and take out the cmos battery to reset the password.please help me....
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
May 20, 2010 | Packard Bell (030069) Sound Card
How do i reset the bios or the password using the mother board
Hi.
1.open your system, find a small coin sized CMOS battery on your motherboard.
2. Remove it and leave your system for around 20 mins and replace the battery back and restart your system.
3. Your BIOS settings will be replaced to default including password.
I hope this is helpful to you
Thanks
Mar 16, 2010 | Packard Bell Computers & Internet
Lost bios password
Pull the CMOS battery (the round thing) off your motherboard for 15 minutes, then put it back in. It should clear out your bios password.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
Sep 30, 2009 | Packard Bell Computers & Internet
Easynote will not go past packard bell screen
You may need BIOS update. Check your CMOS time at bios page.
If time is wrong, set it up and try again. If this is solved the problem, change the CMOS battery.
JMC
Aug 15, 2009 | Computers & Internet
WHERE DO I FIND PASSWORDS FOR BOOT AND SETUP
here the reply i left for another problem of the same sort just with an IBM. the process for undooing this is similar for most laptops so just apply Packard Bell instead of IBM
the only solutions i know are both non easy fixes. one is to strip down the laptop and find the bios battery if it has one. then pull it, leave it 30 seconds and put it back in, rebuild and all will be well. the other is to get hold of IBM and fax them proof of ID and ownership (the usualy request although i havent done it with IBM yet) and they have an unlocking set of passwords which is written into the BIOS.
Jun 09, 2009 | Packard Bell Easy One Silver 2120 Notebook
Packard Bell Easynote MZ36 24 uk
You could search the internet for Bios Master passwords. Other than that, just pull the ac power, main battery and cmos battery and let the system drain.
If its a Windows password, then respond back for more instructions.
Oct 23, 2008 | Packard Bell Easy One Silver 2120 Notebook
Computers & Internet Logo
Top Packard Bell Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
