Question about PRINTER Office Equipment & Supplies
Barcode printer EasyCoder 3400E not printing PDF with barcode font (font 3OF9)
Posted by Ashutosh Arora on
ENFORCER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • PRINTER Master
  • 38,673 Answers
Pdf is the wrong file type for a barcode printer.
https://www.barcode.graphics/barcode-image-file-formats/
Posted on Mar 03, 2021
Testimonial: "it is printing content from PDF file. Just that PDF with barcode is not getting printed."
ADMIN Eric
    Top Expert:
  • PRINTER Master
  • 37,881 Answers
Load the font first in your printer command.
Testimonial: "The font is already loaded/available in printer preferences. Using this on windows machine. The printer driver version is 6.3.9600. Is this driver or firmware related?"
  • Tech Support
    Tech Support Jun 24, 2022
    This is probably not firmware related. There is an option for windows direct printing which would allow you to send the commands directly. There's another option (shown in Labelview and Bartender, but should work elsewhere) where you can send the file to be printed as an image. This would remove any squares or squiggly lines that would show if the font was not interpreted correctly by the driver.
    Lastly, you can try to update the driver.
    Visit us at www.bartechsystems.com for your barcode and label supplies
5 Related Answers
Anonymous
  • 53 Answers
SOURCE: improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
Posted on Nov 09, 2007
Anonymous
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
LinuxHippie
SOURCE: 304 barcode damaged
Try one of the following:
1. Turn the printer off, then back on
2. Reverse the ribbon; perhaps it is upside down
Once the printer is powered on and the ribbon is in correctly, the printer should work.
Posted on Mar 27, 2009
Anonymous
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
Anonymous
  • 257 Answers
SOURCE: ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Posted on Jul 15, 2009
Printing barcode using font 39
The printer can get out of "phase" and the print will look shaky. These instructions are for the P5000 but the phasing process has not changed.
http://themrpsolution.com/v//vspfiles/Tech%20Tips%20Q&A/Printronix/P5000_phasing.pdf
Can i print barcode from pr2e matrix printer?
With a matrix printer it may be easier to scan the barcode as a .jpg picture, then print the picture, which will include the bars and the digits
2answers
Barcode
If the bar code you need is one of the resident barcodes either on the printer or as a sofr font you should be fine.
On Lexmark printers you can go into the printer menus, select fonts and then print out the resident fonts on your printer.
If you are using windows, you can see the available fonts, by clicking on the font down arrow.
Don
1helpful
2answers
Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
BAR CODE FONTS FOR LITTLE LABELS
Depends on what software you are using, but you can use any True Type Font for the human readable, and any propritry barcode font available as downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Printing AklphaNumberic Barcode using I2of5 Format
Indeed, I2of5 is numeric, use the 3of9 or 128 A or B to encode alphanumeric characters. Roberto Martinez Mexico [email protected]
2answers
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
2answers
Won't read fonts
Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it (usually by scanning it) to original factory configuration or scan a label that would enable all symbologies.
Top PRINTER Office Equipment & Supplies Experts
vince
Marvin
Marvin
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
