Question about Sanyo Televison & Video
I have a Sanyo plasma TV I have a g x f a Sanyo remote but I can't find the TV button or an antenna but I have an antenna hooked to it from the roof but I can't get it to program any channels
Posted by Donna Fox on
    Top Expert:
  • Sanyo Master
  • 76,582 Answers
Check the remote control for its infrared emission first. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it.
https://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
https://electrohelponline.blogspot.com/
Posted on Mar 03, 2021
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: I need to program my tv to Cable but I don't have a remote
You'll need to get a universal remote if not the original... The original can be purchased from places like anyremote.com and a good universal from Radio Shack... I'd strongly recommend getting the original because some features are ONLY accessible through the original remote. Good Luck! Bill
Posted on Jun 04, 2007
Orlando Labra
  • 93 Answers
SOURCE: cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
Posted on Nov 07, 2007
Anonymous
SOURCE: Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Posted on Jan 11, 2008
Anonymous
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Posted on Mar 31, 2008
Anonymous
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Posted on May 25, 2008
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Can you find me a replacement remote for my older sanyo plasma tv?
Anon, replacement remote for older sanyo plasma tv. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sanyo LCD HDTV TV Remote Control GXBC GXAB GXBJ GXBD HT32546 DP50747...
Sanyo Remote GXBJ eBay
Welcome to Remote Central Universal Remote Control Reviews More
How to Program Universal Remote
https://electrohelponline.blogspot.ca/
Sep 26, 2014 | Sanyo HP261000500A T-Con Board V26DC1.,...
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
Ge antenna 24700
Hi Patrick,
A fuzzy signal on a plasma TV is not common anymore as with the lack of analog TV transmission the signal is either there or it is not.
A amplified HD TV antenna is not always a solution and often times to get a good HD type reception a good outside antenna is required. I have two $100 antennas high up on my roof and still you can get a loss of data stream when the weather is bad. I also use distribution amplifiers to feed several TV's
In the case that the picture is fuzzy but still there it might be a resolution setting that is wrong so hit the menu button on the remote and see if that display is clear- if it is then try setting a different resolution for the input that you are getting fuzzy signal on.
Aug 10, 2012 | Televison & Video
I am tire of cable and want to use an antenna, I have hooked an antenna to the tv checked the hook up and it is secure, but am getting no signal...I have been trying to find a place to change from cable to...
After u hook up the antenna source like a digital or a roof antena to the tv.Used ur remote go into the tv menu.Goto SETUP,go down to CH.Pick AIR enter and scan for free air DTV channels.
Feb 25, 2011 | LG 32LG30 32 in. LCD HDTV
Tv not responding to remote
This may sound silly but does the remote have a funtion button or buttons at the top of the remote? It may be set to operate a DVD or VCR instead of the TV.
Failing that check the batteries, it is very rate that your TV will stop accepting IR signals.
Hope this helps,
Cheers
Jan 06, 2010 | Sanyo DP50747 50 in. Plasma TV
Tv antenna
hiya
the antenna is normally on the roof. then a cable runs from the aerial to the tv
Feb 26, 2009 | Hyundai ImageQuest PD421 42 in. HD-Ready...
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
