Question about Samsung Televison & Video
I have an 8500 series 55 curved samsung that is displaying vertical colored lines - Someone mentioned it being a tcon board. How do I access the tcon board? .
Posted by Leland Short on
    Top Expert:
  • Samsung Master
  • 76,582 Answers
In most of the modern LCD TVs made by Samsung, the T'Con board is an integral part of the screen. It cannot be replaced by you, or can accessed. It will be best to contact the authorized service center for Samsung. If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Posted on Mar 03, 2021
  • Leland Short
    Leland Short Mar 03, 2021
    Thanks so much - That is the conclusion I came to as well when getting everything opened. Looks like it is largely connected to the panel
Samsung tv has vertical lines and washed out appearance why
OMG..why so many bad answers on here all a sudden ...Chances are you have a bad Tcon board or its possible it could be the main as well however tcons fail way more than main boards with your issue, vertical lines means bad tcon, horizontal can mean a bad display...I can count on one hand the times Ive had a bad display with vertical lines and Ive serviced thousands of HD TV's over the years...but what I want you to do 1st is remove the LVDS cable that goes from the main board to the tcon board, clean the contacts and replace it...then do the same to the two flat panel ribbons that go from the tcon board to the panel, its not real common but on occasion they will loose connection and give vertical lines, don't want you to buy a board if cleaning the cable connections will help...just use a little rubbing alcohol to clean them...Good luck, if you need more help feel free to message me back.
Mar 26, 2018 | Samsung Televison & Video
Samsung 55 led tv has horizontal line across center of screen 1 pixel width changes color as signal changes
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 23, 2017 | Samsung Televison & Video
My 55" led samsung tv has 2 horizonal lines on it and the left side of the tv doesn't have much color and it has trails. Is there any fix for this?
The TCON Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
Jan 11, 2017 | Samsung Televison & Video
My Samsung tv ha vertical line through the picture. Is it time for a new tv?
The TCON board or the LCD panel is Faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 29, 2016 | Samsung Televison & Video
Vizio 55 inch T V/ model # SV470M
If you wish to get some details about flat panel TV repair then check the following link.
Jul 24, 2016 | Vizio 8 Feet High Speed Hdmi Cable Model...
Vertical color lines on an Insignia 55 inch t.v.
May 14, 2016 | Insignia Televison & Video
My Samsung LED tv recently developed a series of vertical white lines on screen. More intense when white text or bright object appears on screen
Tcon board or the LCD panel is faulty. Can confirm by replacing the tcon Board.
May 08, 2016 | Samsung Televison & Video
Vertical green lines on the feft
The tcon board or the mother board is faulty. can confirm by replacing the TCON board.
Apr 27, 2016 | Samsung 46" 7500 Series Full HD Smart 3D...
Colored vertical lines bleeding down
sounds like a Tcon board issue or possibly a bad LCD panel. Can you post a picture of the lines? If so please respond to this same post for further assistance
Jan 01, 2013 | Samsung LN55A950 55 in. LCD TV
Televison & Video Logo
Demonic-2011
Demonic-2011
