Question about Samsung Televison & Video
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name and model of your set, in its search bar at the right side column, and press enter.
Posted on Mar 03, 2021
SOURCE: Replacing main board
Westinghouse LVM-37W1 37 in. LCD hd MONITOR THE TV WHEN YOU TURN IT WILL NOT STAY ON IT CUTS OFF THE TV REPAIR MAN SAYS IT NEEDS A NEW MAIN BOARD
Posted on Feb 24, 2009
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
SOURCE: hp-t4254 On Off issue...somewhat same as others
alguien me puede ayudar me pasa lo mismo
Posted on Jan 01, 2010
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
Mar 21, 2018 | Samsung Televison & Video
Oct 02, 2017 | Samsung Televison & Video
Jul 03, 2017 | Panasonic Televison & Video
Mar 31, 2016 | Samsung UN Televison & Video
Dec 09, 2015 | Samsung Televison & Video
Nov 01, 2012 | Samsung LN Televison & Video
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
