Question about LG Televison & Video
My LG Remote has no home button. And I need to access the home screen
Posted by Goodness Chinda on
Emmanuel Kimutai
    Welcome Back:
    Visited the website for 2 consecutive days.
Press the menu button
Posted on Mar 04, 2021
How to operate a LG smart tv
hi linda.
Press the Smart button on the included remote to access the Smart Home menu. From there, the LG Smart TV will take you through a setup wizard. Follow the onscreen prompts to connect to your home's Wi-Fi and your cable box. Once connected, you'll be able to access online videos, apps and more.
How to Set Up Your LG Smart TV: Geek Squad - Best Buy
https://www.bestbuy.com/site/tech-tips/set-up-lg-smart-tv/pcmcat748301880322.c?id...
How to operate LG smart tv Google Search
Nov 07, 2017 | LG Televison & Video
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Audio Players & Recorders
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
How to get Menu service
1 Press Home to access the Home menu.
2 Press the Navigation buttons to select the SETUP menu and press ENTER.
3 Press the Navigation buttons to scroll to one of the following menus and press ENTER.
4 Press the Navigation buttons to scroll to the setting or option you want and press ENTER.
5 When you are finished, press EXIT
hope it helps. :)
May 08, 2014 | LG 42LD550 42-Inch 1080p 120 Hz LCD Hdtv...
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Feb 07, 2014 | LG Televison & Video
Lg qwerty
contact google or lg
Apr 19, 2017 | LG Televison & Video
My 32 in 2011 smart tv has aproblem. the lg apps will not initialise and the home screen locks up. then there is no response from remote at all. i turn the tv off and on then it works but if i try to go to...
I have the exact same problem, it started straight after the last os update. If u try entering the home screen right after turning the tv on it will allow u to enter but the apps won't initialize and the tv will lock up in the home screen as soon as u press any button on the remote apart from the back button. I have no idea what is causing it but if anyone out there has any idea of the cause or even better a solution can u please let us know.
Aug 27, 2011 | LG Televison & Video
Looking to unblock a lg ht502th so it can play all regions
Hi, I have just sucessfully unlocked my LG home theatre HT502TH by do the steps below - good luck
1. Opening DVD Drawer
2. Pressing "0000" on the remote.
3. A screen appears saying NEW REGION CODE and displays the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD Drawer. (may need to do this manually)
7. Power off
Nov 26, 2010 | LG Audio Players & Recorders
MY REMOTE CONTROL FOR THE LG TV :32LG30 STOPPED
Let verify first if the remote is sending out signal, point the remote at your digital camera, you shoud see flashing light on your camera screen (camera can see infrared light) when any remote button is pushed, if you can see it, then the problem can be in the Infrared receiver in your TV and need further troubleshooting.
You can get new remote on EBAY.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | LG 32LG30 32 in. LCD HDTV
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
