Question about Refrigerators
Temperature display in wine fridge does not show numbers clearly
Posted by John Truro on
Fritz Bezuidenhout
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Move to dark location.
Posted on Mar 05, 2021
5 Related Answers
Anonymous
SOURCE: K-Mart Homemaker brand, 40 bottle wine cooler fridge
Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
Posted on Jul 04, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Posted on Jan 02, 2010
Testimonial: "Thank you for the quick response!!!!"
Anonymous
  • 13 Answers
SOURCE: Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Posted on Jun 01, 2010
Anonymous
  • 24 Answers
SOURCE: We just plugged in the
let it run 12 hrs for temp. balance.
Posted on Dec 26, 2010
Anonymous
  • 15 Answers
SOURCE: Wine cooler displays temperature setting but does
It's 1 of 3 things...
A. The fans are not turning. Remove the back, and see if the fans are getting 12 volts, and spinning freely. Remove them and clean off the dust from the heat sink.
B. The Peltier Chip is shot. If the fans run, check for 12 volts on the power connector that's on thelower left of the curcuit board. If there's power, but no cooling, the Peltier is shot. These are available from E-bay for ~$13, but it's a major dissassembly to get it out.
C. If you don't get 12 volts to the fans or the Peltier chip, replace the circuit board.
Posted on Jan 05, 2011
I have a igloo 48 bottle wine cooler, and it will show error code "LC" and then you can not adjust the digital temperature or turn the light on. It fridge still feels code? Any ideas would be great!
Could be the temperature sensor. There should be a support number in the manual you can call. Hope you can get it fixed. if not check out my blog for help choosing your next cooler. The Best Wine Coolers The Complete Guide Vino Coolers
Jun 07, 2016 | Furniture
CL flashing even though the coils have been cleaned. unable to reset wine fridge
To clear the alarm:
1) Press and release the "SET button four times. "cnd" will be displayed on the screen.
2) While "cnd" is displayed, press and hold the "SET" button. The display will show the number of weeks the refrigerator has been running.
3) While holding the "SET" button, press and release the ON/OFF button. The number shown on the display will reset to 0.
4) Release the "SET" key.
Jan 12, 2014 | Marvel 30WCM Wine Cooler
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Jul 31, 2012 | Furniture
What kind of cooler should I get if I plan on storing both red and white wines in the same fridge?
You need a dual zone wine cooler. They have two temperature controls and the storage space is divided in such a way that each temperature control has its own section inside the cooler; allowing you to store both red and white wines properly.
Wine cooler too cold, compressor keeps running, temperature display is off
Let me first go over how a sealed system actually works that way when I tell you whats wrong you won't think I'm crazy. There are two sides to the freon system, known as the sealed system. The low side, where freon is in a gas form. In this form, freons temperature is at its coldest. Now, the freon can't just sit because movement is required for it to be cold. The high side does this by compressing the gas into a liquid,which pressure causes the temperature to rise, and forcing it through to the low side where it becomes a gas. So, with that said, the more freon in a sealed system the more pressure is applied, causing a higher temperature because less time as a gas. This is how they make wine coolers, walk in fridges, etc cool, not freeze. If you were to remove freon, the temperarture would get colder. Your wine cooler should have enough freon to prevent this from happening, and it doesn't therefor the freon has more time as a gas. Either you have a leak, or you've somehow knocked a freon line loose. It should have a year warranty on it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 18, 2012 | Refrigerators
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Temperature control
Click on the link bellow then type in your model number then hit go to display your manual
http://www.haieramerica.com/en/support/modelsearch
Nov 30, 2007 | Haier BC112G Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
