Question about Dryers
Replaced motor. Terrible electrical smell from front. Stops after 30 minutes and can be started again after short cool down. How do I test controller?
Posted by Terry L Davis on
Dale Copeland
    Novelist:
  • 140 Answers
No brand, no model - impossible to be specific.
If it runs 30 minutes before stopping and then restarts after cooling be very suspicious of a restricted/blocked airflow. It would be unusual for a control to cause this sort of problem. Look at the ducting, look for debris/clothing in the lint screen area or the blower wheel. Pull unit away from the wall, disconnect from house ducting and run to see if problem persists. Airflow restriction seems the most likely culprit with the extremely limited information supplied. Good luck.
Posted on Mar 06, 2021
Electric motor heats up and stops after using for about 15 to 20 minutes, when it cools it runs for a short time
hi, now there is a real possibility the brake is not releasing fully , stressing the motor out ,,, have you removed a brush to inspect inside ? what about smell, ? smell burning ?
, Carefully remove the brake and test but keep it connected ?
The windings here could be the issue if the brake is not causing the problem
Areas to look at are :
Brake
Brushes
Motor Commutator
Motor winding , have one of the magnets within the motor come loose... noise would be a issue here..
Regards
Rob
www.gewizrepairs.co.uk
Apr 27, 2015 | Electric Health & Beauty
My treadmill stops running after 3 minutes. It shuts down and I have to reset and start over again. After another 3 minutes, it shuts off again.
Sounds like a motor or electrical system cooling problem. Could be dirt or blocked motor. Try Computer air blast can and or a vacuum to clean out motor and electronics.
Mar 04, 2015 | Proform Crosswalk Advanced Cr 525i 525x...
GE electric dryer 1 year old
Most likely motor is bad. It runs a little while,overheats, and shuts off. After cooling down it will restart and repeats process.
Oct 17, 2017 | Dryers
Air conditioner cools for 30 minutes then stops cooling after 20 minutes starts cooling again what is likely problem
The compressor motor is over heating and thermal protection shuts it down , when it cools down it restarts. Restricted air flow over the cooling coils could be the cause. Check filter,Sometimes furniture or other things block the return air vent.
Aug 27, 2014 | Heating & Cooling
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
1992 dodge dynasty 3.3 engine runs then after so many miles, it hesitate/sputters and stops
Depending on how old fuel pump is, and quite often you will notice the buzzing/humming of pump at rear of car getting noisier. If vehicle re-starts after sitting 20-30 minutes and drives for a while again before same happens, I would certainly consider having fuel pressure tested. Hard part is to get it tested when vehicle fails to start, because by the time it gets to a shop, the pump has cooled down and works for a short time again. Not uncommon for the pump to have good pressure when cool, and heat up and lose pressure when driven or been running for a while.
Jul 01, 2011 | 1990 Dodge Shadow
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
My ge washer starts spining to drain water then stops
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
Apr 30, 2009 | Washing Machines
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
Marvin
Marvin
