01 - Freezer Temperature is Above 10 Degrees F (-12C)
If the freezer temperature is above 10 degrees Fahrenheit (-12C), the ice maker will not produce ice cubes efficiently. The freezer temperature should be set between 0 and 5 degrees Fahrenheit (-18 to -15C) for the ice maker to work properly. If the freezer temperature is too high, ensure that the condenser coils are clear of debris and the condenser fan is working properly. In addition, check to see if frost has accumulated on the evaporator coils. If the evaporator coils are frosted over, part of the defrost system has likely failed.
SOURCE: Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
The trough gets refilled on each ice cycle, if it's circulating, then the water supply is adequate.Y
The exact model would be helpful, but you could call 1-800-779-2547 U-Line's tech line
or email [email protected] for help
http://www.U-Lineservice.com
SOURCE: uline ice maker clr2060- makes ice continuously,
This is a problem when the thermistor in your icebin is not being satisfied.Now there is a break in the serial number to find out if you have a thermistor or a mechanical thermostat. If the serial number is before 03 (first 2 digits is the year)and the 2 digits between the dashes is 11(the month) the replace the bin thermostat. If newer then you need to replace board and thermistors.
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
This happens when the teflon on the mold is peeling.(flaking) It pushes water over the side. Otherwise check the clip in the back that holds the fill tube in the water cup. If the clip is missing then the fill tube could be splashing water over the mold
