Question about The Audio Players & Recorders
This is a follow-up to your other post. This doesn't not work because posts aren't threaded by user. Therefore, this post has no relevance to the other. You can go back to your other post, click EDIT and add this bit back in with copy and paste and then Delete this one. Or I can Edit it in.
Posted on Feb 28, 2021
SOURCE: Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Posted on Jan 01, 2008
SOURCE: No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Posted on Feb 16, 2008
SOURCE: RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Posted on Mar 17, 2008
SOURCE: My tv keeps turning off and changing channels.
You have a bad Main bd.
Posted on Jul 17, 2009
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
I hope that helps.
Posted on Dec 26, 2009
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
Dec 15, 2013 | Audio Players & Recorders
Sep 24, 2011 | Behringer PMP6000 VP1520 PA Package
Jan 25, 2011 | RCA Audio Players & Recorders
Jun 21, 2010 | Adcom GFA-5802 2-Channel Amplifier
Oct 26, 2009 | Adcom GFA-5400 2-Channel Amplifier
Apr 03, 2009 | Yamaha P-2500 Amplifier
Dec 31, 2007 | Audio Players & Recorders
Mar 10, 2007 | Earthquake Sound PH-D3 Car Audio Amplifier
Dec 21, 2020 | The Audio Players & Recorders
Dec 19, 2020 | The Audio Players & Recorders
