Worked great then moved to new home and this is error we got right away.
And what did LG tell you might be the problem ?
learn to use google here is a link for you to check out things
https://www.google.com/search?q=What+does+p5+error+mean+on+my+electric+LG+dryer&oq=What+does+p5+error+mean+on+my+electric+LG+dryer&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Posted on Apr 17, 2021
SOURCE: converting gas dryer to electric
No. There is no conversion. They work very differently.
Posted on Dec 18, 2007
SOURCE: LER4634E WHIRLPOOL FRONTLOAD ELECTRIC DRYER WORKED GREAT
If you have a access to an AC voltmeter, measure the two slanted connections in the wall socket for ~220 volts. If near zero, measure at the load side of the dual breakers for the same voltage. If still at or near zero, one of the breakers has gone south. Replace the pair of breakers.
If you measured 220 volts as above, then the problem is within the dryer--probably a burned out heating element or open thermal fuse. Major tear-down to find and fix as the heating element is behind the drum.
Posted on Jul 17, 2009
SOURCE: Hello we have an LG electric
Check your local building supply like Lowes, Homedpot and such.
Posted on Jan 01, 2011
SOURCE: What do the "T" error codes mean in regards to GE electric dryer model # DCVH515EFOWW
YOU must see you instruction manual section troubleshooting and Fix it.
if you do not have download the instruction manual from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Posted on Jun 19, 2012
