Fuse appears to be good and unit will still not power up.
Posted by W. H. Liem on
    Top Expert:
  • Televison & ... Master
  • 76,582 Answers
What is the brand name and model number of your device? If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Mar 01, 2021
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
Yesterday my wife had the car battery replaced by the RAC and her Pioneer DEH-2050MPG unit doesn't work now and gets no power to it. I checked the car fuse for the radio and it appears to be okay
Check all of your fuses. There are probably two fuse boxes in the vehicle. There may be a fuse either inline or on the back of the radio.
Dec 25, 2012 | Car Audio & Video
Kitchenaid dishwasher model kuds40cvwho does not run. The unit receives power. The latch appears to be working properly. The thermal fuse shows 0 resistance n the ohm meter.
In addation to the thermal fuse have you checked the door switchs to be 0 ohms resistiance as well??
ya made need to trick the latch to thinking its closed so ya can check the switches in the door closed position
If the switches do check to be good and the thermal fuse is known to be good the problem will be with the control board and long as verifing that their is power at the thermal fuse/into the control
Sep 24, 2011 | Dishwashers
The microwave will not operate or turn on even though it has power
The main fuse in the microwave has blown, this is often caused by a defective door switch.
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Unit will not start up. Push on button. Just dead. Appears to be connected correctly to a good battery. What could be the problem.? Are there fuses involved? Thank you for your help. Larry
There should be an in-line fusible link on the power supply wire and it should be checked for a blown fuse. If there is no fuse protecting the head unit, it may have received a voltage spike internally and caused internal circuit damage, requiring replacement. What can be done is remove the head display unit and wire it (with a fuse link) to battery posts and see if it powers up. If the unit does not come on, then the head unit will need to be replaced.
Dec 04, 2010 | Humminbird Piranhamax 220 Fishfinder
Doesn't want to stay on
If your GPS unit powers down before it can fully boot up, use the steps below to charge the GPS unit and test the vehicle power cable:
  1. Connect device to a computer that is powered on
    • The unit should power On when you plug it in showing a computer plugged into the GPS unit on the screen (Mass Storage Mode)
  2. Press Reset button on the bottom of device if it does not power On*
  3. Allow the unit to set and charge for 3-4 hours
Once the device is charged please take it to the vehicle and test it on the vehicle power cable.
  1. Connect the device to the vehicle power cable
  2. Connect the vehicle power cable to outlet on vehicle
  3. Power the vehicle On
  4. Device should automatically power on
    • If a battery icon appears directly to the left of the time then it is not receiving a charge from the vehicle
    • Please check the fuse in the vehicle power cable
      • The end of the cable unscrews to reveal this fuse
      • Check to make sure the wire element inside the fuse is in contact and that there is no discoloration.
      • If you see either of these the fuse needs to be replaced with the replacement fuse specifications listed on the sticker attached to the cable.
      • If the fuse looks good and there is still no light, the vehicle power outlet may need to be checked to see if it has power.
*Note - The reset button may be found on either the left or right side. In some cases if the device does not have a reset button slide the power key to the left or On position for about 10 - 15 seconds.
Oct 23, 2010 | Garmin nuvi 200W GPS Receiver
Fuse f2 has blown on my R-957 (sl) M jet convection and grill microwave any ideas ? Thanks
To check the internal fuse, you will need to remove the outer case. Disconnect the power and remove all screws from the back of the unit that appear to be holding the case in place. Most makes will then remove the case by sliding them toward the the back of the unit. The fuse should be easily accessable in the control panel area. Most will pull right out for inspection. If the fuse is bad, you can usually get a replacement at Radio Shack. Take the old one with you. Good luck.
Jun 20, 2010 | Microwave Ovens
No power to unit.
tr opening the microwave you should find a litle glas fuse in it take a look and see if its blown if so replace it maplins sell them and that should fix it good luck
Nov 27, 2009 | Washing Machines
Sony str-da50es. Does not power when power button is pushed.
This problem is very common in this model the solution is to replace the fuse with improved one 10A 125V of type CES710A having part No.1-576-695-11. Remember that this fuse would be larger in size of earlier one so that you have to drill it first in the holder and adjust the fuse to a proper space of 1.4 drill bit.
Do the changes and your product work fine.
Thanks.
Nov 24, 2009 | Sony STR-DA50ES Receiver
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
