Hi! I bought a MemoQ Slim Audio Recording Pen and a Dual USB Port Universal Wall Charger to charge the battery. Should I use the 1.0A output or the can I use the 2,1 output to charge the battery?
Posted by [email protected] on
Ngoro
    Top Expert:
  • Office Equip... Master
  • 3,144 Answers
It doesn't matter which output of the charger you use. Your device definitely consumes less than 1.0 amp when charging.
https://www.howtogeek.com/175734/htg-explains-can-you-use-any-charger-with-any-device/
Posted on Mar 01, 2021
Can I charge an RCA MP3 player TH2014T directly into wall outlet in europe or do I need a voltage converter from 240 v to 110v?
First, I'm not a RCA representative.
* Check your warranty. Call for support; https://rcaav.com/audio-video/
*** Following is for information only. ***
* Specs (and questions); https://www.amazon.com/RCA-TH2014-4GB-MP3-Player/dp/B015S9NTLO
* Customer review (shows charging); https://www.youtube.com/watch?v=ggQwsI1B__8
* according to the specs. A customer says it comes with a large battery(?) but the specs say it uses a USB plug in to charge.
* USB plugs (that are charge plugs) just plug into any standard USB (5VDC) charger.
* The USB charger will plug into the wall outlet power that is available in the area. Albeit 110 or 240VAC.
* Taking a charger from USA will not fit into a European outlet as they are very different. (though plug adapters are avail. I don't recommend them unless they were supplied with the USB Charger AND specifically states the dual voltages on the charger ID plate. )
* European chargers looks like; https://www.amazon.com/European-Adapter-Niluoya-Universal-Charger/dp/B07CBSFPV5/ref=sr_1_3?ie=UTF8&qid=1531557442&sr=8-3&keywords=usb+charger+european+plug&dpID=41%252BXpN9gxAL&preST=_SY300_QL70_&dpSrc=srch
* But you will be able to charge at any USB standard charging port without using your original charger. (Though you may need to heed the "USB3" ports that may overcharge your device. You will need to contact support to get specifics on what power level (USB 1-2-3 types) you can safely use.
* Diff Europe adapters( and warnings) ; https://www.youtube.com/watch?v=kAQ4FaaH8Lk
* Note; There are different plugs in England.
* When in doubt, use USB with 300 ma rating. (which is a very safe slow charge at a low power rate. It won't heat up anything at this power level.)
* WalMart; https://www.google.com/search?client=firefox-b-1&biw=1366&bih=654&tbm=shop&ei=v7ZJW6f9EICx0PEPu86s2A8&q=usb+charger+european+plug+walmart&oq=usb+charger+european+plug+walmart&gs_l=psy-ab.12...7685.10539.0.12156.8.8.0.0.0.0.153.965.0j8.8.0....0...1c.1.64.psy-ab..0.0.0....0.tdeufG-_8LU#spd=5599713413149077881
Aloha, ukeboy57
Jul 14, 2018 | RCA Audio Players & Recorders
Cant remember my account info to add two ne fires to our account can you help?
Hello Brenda Hall,
We are familiar with all Kindle devices, and we also know how to manage Kindle devices in order to make them perform in a better way. So, you just have to Call Toll-Free +1(844)-305-0086
in order to know how to manage your Kindle tablet.
Have a nice day!!!!!!!!!!
Dec 22, 2015 | EEEKit for Samsung Galaxy Tab II P3100...
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
Why wont my sanyo vc-e760 hold a charge
Since you've already tried different batteries, you have a couple of other options...
  • Instead of plugging the USB cable into the camera's wall charger, plug it into the USB port of a computer, or even into a USB phone charger.
  • Try another wall charger.
  • Try another USB cable.
Here's the PDF manual for your camera, if you need it: http://us.sanyo.com/dynamic/extranet/servicers/VPCT1495.pdf
(Page 16 contains info about charging the camera)
Aug 04, 2014 | Sanyo Cameras
How is NewNow Bamboo VI 15600mAh external battery ?
I think you have an extra zero in that mAh rating...Make sure to fully charge and discharge a couple of times for full capacity and longevity of the battery.
May 27, 2014 | Electronics - Others
Spy pen not working
If you have a Spy Pen, sometimes it just appears to be either stuck with the light on, or dead and won't turn on. We wrote this report to show you some of the tricks we found to getting your it to work again.
1. Perform A Hard Reset
The majority of the time, just inserting the end of a paper clip in the opening below the status light on the back, and performing a hard reset, will get your Spy Pen working. Just bend a small paper clip end out, and insert straight into the opening. When you meet resistance, push lightly, and you can feel the reset button depressed.
Make sure it goes straight in, and not at an angle, or you could damage some of the components inside. Let go and try to turn it on.
2. Rule Out The USB Cable
If you are using a USB cable to either connect the Spy Pen to your computer, or to the 110V wall charger adapter, one day the cable will fail. If you use the USB cable because you can't connect the pen directly to the computer, try just plugging it directly into the computer.
Don't use a USB hub, as sometimes there is not enough power for the it; just connect it directly to the computers USB port. On some computers, use the USB port on the back, as front USB ports are sometimes weaker.
3. Rule Out The 110V Wall Charger
Just like the USB cable, the 110V wall charger adapter will also fail at some point; so if it does not seem to take a charge, try charging it for 3 hours in the computers USB port. If the status light is on while its charging, its getting electricity to charge the battery.
4. Put The Spy Pen Back In Video Mode
Several Spy Pens have switches to go to photo mode, or voice activation mode. If you move the switch to change modes, and you do not move it back to video mode, the computer will say it is not recognized. Try moving the switch back to the original position.
5. Erase & Reformat The Spy Pen
If the Spy Pen shows up as a removable drive on your PC, just right click on the icon and let go on "Format." Then check the "Quick Format" button, then hit OK. The drive will be erased, and reformatted. This usually takes care of any pens that make it this far.
Feb 13, 2014 | Computers & Internet
My fuse wont charge at all. i bought a new charger and still get no charge
Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode
Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0
Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC charger (optional)
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
I bought an untested Samsung L730 digital camera without a battery, I have bought a USB charger/data cable but the orange flashing light on the charger stays on. I am using Windows XP. Is it likely that...
You CANNOT charge a camera through a USB port there just is not enough power! you need to get an original wall charger and power up from that. Even the USB cable/wall charger will NEVER charge it up sufficiently.
The USB cable is for data transfer only.
Aug 07, 2010 | Samsung Digimax L730 Digital Camera
Charger port problem
http://www.accessorygeeks.com/universal-travel-charger.html
or google BTC-UNI
iT'S little cheesy but hey for $10 and free shipping I can eat a lot of cheese.
Just plug your battery into this little clugy thing, plug the thing into the wall, wait until battery is charged and then put your battery back into your phone...presto...for this kind of money who cares if the VX9900 has a dead battery charge port.
I bought two, they were on sale for $7 each. It's ugly and takes a bit of patience but it works.
Feb 26, 2008 | LG enV VX9900 Cellular Phone
k24674
