Question about Ricoh Office Equipment & Supplies
Sometimes Door open error shows in printer even if it is closed .
Follow This steps to Fix Open Door Error Message:-
*Close the cartridge access door completely.
*Check the cartridge door for obstruction.
*Reset the Printer
*Restart the Print Spool Device.
*Restart the computer.Restart the Printer.And If you are using Brother Printer And You Encounter With Brother Printer In Error State Windows 10 Issue then Read The Blog I Am Mentioning above.
Posted on Apr 10, 2021
SOURCE: Door open error on HP6840 printer when door is closed
Here's the answer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065334&cc=us&lc=en&dlc=en&product=385458
The sensor is probably stuck, and it took me a few minutes to fix!!
Good luck...
Peter
Posted on Apr 30, 2009
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
Posted on May 29, 2009
SOURCE: rear hatch door won't lock dash light showing
You need to tighten the lock mech on the boot lid. this will close the boot just enough more to turn the light on. It's no biggy, you might need a star driver depending on bolt head. move it into the boot lid approx 4mm to start. then 1mm until 10mm. if no joy then it may be the sensor.
All the best
Ally A
Posted on Jul 25, 2009
SOURCE: Door open !
check the door switch under the cover: if bent straighten it, if broken amend.
Posted on Feb 03, 2010
SOURCE: Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Posted on Mar 27, 2010
Nov 07, 2017 | Ricoh Office Equipment & Supplies
Sep 29, 2014 | Ricoh Aficio Mp 3352 B&w Copier
Apr 29, 2013 | Ricoh Aficio MP 161 Black and White Copier
Jun 06, 2012 | Lexus RX 300 Cars & Trucks
Mar 30, 2012 | Gestetner Office Equipment & Supplies
Mar 01, 2011 | Ricoh Aficio 2035 Copier
Jan 08, 2011 | Ricoh Aficio MP 161 Black and White Copier
Sep 23, 2010 | Ricoh Aficio MP 161 Black and White Copier
Aug 26, 2010 | Office Equipment & Supplies
Nov 28, 2008 | Ricoh Aficio CL3500N Laser Printer
