March 2002 19,500 btu window air conditioner ,will not turn off.how do I turn it off? Electronic PC bad ?whirlpool
Posted by Ed snyder on
David Spradling
    Top Expert:
  • Heating & Co... Master
  • 12,034 Answers
Possible bad temp sensor or relay stuck on
Posted on Mar 07, 2021
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
Posted on Jun 10, 2008
Priya darshan
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
Don Berry
  • 230 Answers
SOURCE: Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Posted on Jun 27, 2008
Anonymous
SOURCE: My Haier 5,200-BTU Window Air Conditioner keeps freezing up.
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Posted on Sep 24, 2008
greenspan
Remmy Moore
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
Freezing up 8000 btu window unit
Coils may be dirty, filter may be dirty, water not draining or low on freon.
Jul 25, 2010 | Whirlpool Electronic Window Air...
4 year old Whirlpool 12000 btu ac does not blow cold air like it used to
Most likely it need to be service. Unless you know you stuff dont try it.
call your local air conditioning man!
Jun 30, 2010 | Whirlpool Electronic Window Air...
Electronic 6000 btu runs but will not cool
The compressor is not turning on. A common cause for the thermal breaker mounted on the compressor is bad. Unplug the unit and open it. Where the wiresgo into the compressor you will be able to see it. It is inside the black cover on the compressor.
Jun 26, 2010 | LG Electronic Window Air Conditioner
Where do I find how many btu's my unit is. i' trying to figure out how many BTU's my window ac unit is. where do I find this info
Pull off the front cover and then the filter...usually reight behind there is a sticker with the BTU outpit of the unit...model number, serial number, etc...
heatman101
May 29, 2010 | Whirlpool Electronic Window Air...
BTU of air conditioner?
Here are all the specs of the air conditioner whirlpool ACU102PK
Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
Hope this helps you and Good Luck.
May 13, 2010 | Whirlpool ACU102PK Air Conditioner
I need to know the BTU of our Whirlpool Air Conditioner ACQ158XSO
Th info I keep finding is 14,7000 which is just over 1 ton of cooling. Each ton is 12,000 Btu. Probably designed to cool about 400-500 square feet.
Jul 13, 2009 | Whirlpool ACQ158XP Wall/Window Air...
I NEED TO REPLACE A POWER CORD TO MY SMALL AC UNIT
A hardware store will have what you need to repair. Tom
Jun 18, 2009 | Whirlpool Electronic Window Air...
Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
May 31, 2009 | Whirlpool Electronic Window Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
john h
