Is it a 'Computer (laptop - Notebook - Chrome Book)', the Category you posted to, or a phone, or a car battery or a Drill Battery Pack, or......................
All questions must have make model (what it is)
_Most_ chargers have lights, Red flashing for charging, Green for full. _Most_ batteries take about 8 hours to fully charge. You can see _some_ charge in an hour.
Vague answers to a vague question. Click COMMENT under my post and fill in the blanks, and we will tell you the _CORRECT_ answer :>)
It's a Black and Decker cordless Lithium Ion Hand Vaccuum HHV1315JO42
I have the manual and have followed instructions for charging. I guess I will wait 16 hours to see if it has charged. There is no way
to tell if it is charging. The manual that came withe product seems to be for other models.
Great thanks. so it was wrong category. I don't think I can change it now.
Anyway, here is the answer, 24 hours, and make sure the vacuum switch is in the OFF position. You should see a charging light?
Charging the battery
From new, the rechargeable cells of the product need a minimum charge time of 24
hours to ensure full power.
We suggest you fully discharge the product when it is used for the first time as this will
help the cells recharge faster.
• The switch must be in the off (“O”) position, the product will not charge if it is in any
other position.
• Figure F - Plug the jack plug of the charger into the charging socket of the tool. Plug the charger into any standard 120 Volt 60 Hz electrical outlet.
The charging indicator will be lit.
While charging, the charger may get warm, this
is perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to “overcharge” the battery cells
with the charger provided.
• The charging indicator will be lit as long as
the appliance is connected to the plugged-in
charger.
Manual Page 4 refers
https://www.manualowl.com/m/Black%20%26%...
Thanks for changing the Category Steve, Larry will thank you :>)
If the light is on, it is charging. If there is no light, it is because the vacuum is switched on or something is faulty.
