Heating & Cooling Logo
Monitor 2400 heater. What does E13 code indicate?
Posted by Alicia Ross on
ray gallant
    Top Expert:
  • Heating & Co... Master
  • 74,163 Answers
WHAT DOES YOUR LOCAL DEALER TELL YOU ABOUT IT
Posted on Apr 20, 2021
4 Related Answers
Anonymous
SOURCE: have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Posted on Nov 05, 2008
Anonymous
  • 3 Answers
SOURCE: e13 code, monitor 2400
You have an obstruction in your fuel line. Lint or rust or some other debris, either in your main fuel filter which I hope you have or in the small one in the fuel sump on the lower right hand side (the little square hole below the round finger hole for the reset button). The screen is cleanable with air or brakekleen or both. Or it might be that your Constant Level Valve is tripping or has tripped. Push the button in the round hole on the lower right hand one time quickly (don't hold it down or press it several times slowly) and you should hear the float drop. Fuel should resume flowing to the fuel sump at that time.
Posted on Nov 03, 2009
Anonymous
  • 61 Answers
SOURCE: e13 keeps blinking on my monitor 2400 heater
causes of E13 error code:
Failure of ignitor, solenoid pump
or circuit board.
Incorrect wiring or flame rod
touches to burner parts.
Air pressure switch or overheat
open
I recommend taking it to a qualified service center.
Unfortunately, this can be a hard problem to trace with some experience and equipment.
Hope that helps!
-Helping Hands Services-
_Fairbanks, Alaska_
Posted on Nov 21, 2009
Anonymous
SOURCE: Monitor 2400 Kerosene heater service
Drain the air out of the supply line at the bulk tank shutoff valve; there should be a small hex plug for doing this. On the bottom right hand side of the heater is a round hole that allows access to a finger pump for the fuel; press this three times slowly. Heater should start!
Posted on Dec 14, 2010
4helpful
2answers
My daughters 2400 kerosene monitor will light, burn for about 2 to 3 minutes and then go out. The flame starts as a nice blue then goes to orange then looks red and goes out. Please help!
Susan, I suspect you have air in the lines, you will probably have to bleed line at pump. 2nd link explains how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://monitorproducts.com/wp-content/uploads/M2400OwnersManual.pdf
https://ca.answers.yahoo.com/question/index?qid=20070208183218AAEiYdr
monitor heater repair help
Thread Monitor 2400 e13 error code
Monitor heater 2400 turned off with code E13, what does that mean?
This is an over heated indicator, what make and model unit.
How to fix a mpi 2400 with a e13 code how to fix
You need to have the system cleaned up.
6helpful
2answers
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
2helpful
E13 keeps blinking on my monitor 2400 heater
or circuit board.
open
Hope that helps!
_Fairbanks, Alaska_
1helpful
2answers
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
[email protected]
9helpful
E13 code, monitor 2400
4helpful
2answers
I have a Monitor 2400 oil heater. I would like a more detailed description of all the parts for this heater. Also I would like to find a listing of the possible error (e) codes that this heater may display...
I cleaned the fuel screen located on the unit and replaced the filter on the external fuel tank. The external filter can freeze if it accumulates enough water and the temp is cold enough, or it can just get full of debris. I also unplugged the 2400 for 30 min to let the factory preset settings come back. Filter(s) caused the e14 error, preset settings cured the e13 error caused by me fooling with the start stop function so much. Thanks for the help!
114helpful
12answers
Have a mpi monitor flashing a e13 code
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
